February 11, 2021, 05:46 |
Modifying Contact Detection UDF for 3D
Will Crawford-Jones
Rep Power: 5 |
Does anyone have experience of modifying the 2D Contact Detection UDF example in the UDF manual to 3D. This is what I would like to do currently, however there is little information available (as far as I know) on the definitions of the macros involved so it is very difficult to do so. If anyone could point me in the correct direction or has experience with modifying the UDF then please let me know. Any help you can give would be great! Thank you! PS. 2D example is here: /************************************************** ***\ *2-degree of freedom equation of motion compiled UDF * \************************************************* ****/ #include "udf.h" DEFINE_CONTACT(contact_props, dt, contacts) { Objp *o; face_t face; Thread *thread; Domain *domain = NULL; Dynamic_Thread *ndt = NULL; int tid, nid, n_faces; real v0dotn1, v1dotn0; real nc_mag, norm0_mag, norm1_mag; real N3V_VEC (vel_rel); real N3V_VEC (nc), N3V_VEC (nctmp); real N3V_VEC (xc), N3V_VEC (xctmp); real N3V_VEC (vel0), N3V_VEC (omega0), N3V_VEC (theta0), N3V_VEC (norm0); real N3V_VEC (vel1), N3V_VEC (omega1), N3V_VEC (theta1), N3V_VEC (norm1); if (!Data_Valid_P()) { return; } /* Define a common contact point / plane */ N3V_S (nc, =, 0.0); N3V_S (xc, =, 0.0); /* Fetch current thread ID */ tid = THREAD_ID (DT_THREAD (dt)); nid = -1; n_faces = 0; loop (o, contacts) { face = O_F (o); thread = O_F_THREAD (o); /*Skip faces on current thread */ if (THREAD_ID (thread) == tid) { continue; } /*NOTE ID of the other thread for posterity */ if (nid == -1) { nid = THREAD_ID (thread); } /* Initialise to zero */ N3V_S (nctmp, =, 0.0); N3V_S (xctmp, =, 0.0); F_AREA (nctmp, face, thread); F_CENTROID (xctmp, face, thread); /** * Negative sum because wall normals * point out of the fluid domain */ N3V_V (nc, -=, nctmp); N3V_V (xc, +=, xctmp); n_faces++; } # if RP_NODE { /* Reduce in parallel */ nid = PRF_GIHIGH1 (nid); n_faces = PRF_GISUM1 (n_faces); PRF_GRSUM3 (nc[0], nc[1], nc[2]); PRF_GRSUM3 (xc[0], xc[1], xc[2]); } # endif /* Propogate to host */ node_to_host_int_2 (nid, n_faces); node_to_host_real_3 (nc[0], nc[1], nc[2]); node_to_host_real_3 (xc[0], xc[1], xc[2]); if (n_faces > 0) { nc_mag = N3V_MAG (nc) + REAL_MIN; N3V_S (nc, /=, nc_mag); N3V_S (xc, /=, n_faces); } else { return; } Message ( "\nContact:: tid: %d nid: %d n_faces: %d " "Point: (%f %f %f) Normal: (%f %f %f)", tid, nid, n_faces, xc[0], xc[1], xc[2], nc[0], nc[1], nc[2] ); /* Fetch thread for opposite body */ domain = THREAD_DOMAIN (DT_THREAD (dt)); thread = Lookup_Thread (domain, nid); if (NULLP (thread)) { Message("\nWarning: No thread for nid %d ", nid); return; } else { ndt = THREAD_DT (thread); } /* Fetch body parameters */ SDOF_Get_Motion (dt, vel0, omega0, theta0); /* Compute difference vectors and normalise */ N3V_VV (norm0, =, xc, -, DT_CG (dt)); norm0_mag = N3V_MAG (norm0) + REAL_MIN; N3V_S (norm0, /=, norm0_mag); if (NULLP (ndt)) { /*Stationary body/ wall. Use contact normal */ N3V_V (norm1, =, nc); /* Compute relative velocity */ N3V_S (vel1, =, 0.0); N3V_V (vel_rel, =, vel0); } else { /* Fetch body parameters */ SDOF_Get_Motion (ndt, vel1, omega1, theta1); /* Compute relative velocity */ N3V_VV (vel_rel, =, vel0, -, vel1); /* Compute difference vectors and normalise */ N3V_VV (norm1, =, xc, -, DT_CG (ndt)); norm1_mag = N3V_MAG (norm1) + REAL_MIN; N3V_S (norm1, /=, norm1_mag); /* Check if velocity needs to be reversed */ if (N3V_DOT (vel_rel, nc) < 0.0) { /* Reflect velocity across the normal */ v1dotn0 = 2.0 * N3V_DOT (vel1, norm0); N3V_S (norm0, *=, v1dotn0); N3V_V (vel1, -=, norm0); /* Override body velocity */ SDOF_Overwrite_Motion (ndt, vel1, omega1, theta1); } } /* Check if velocity needs to be reversed */ if (N3V_DOT (vel_rel, nc) < 0.0) { /* Reflect velocity across the normal */ v0dotn1 = 2.0 * N3V_DOT (vel0, norm1); N3V_S (norm1, *=, v0dotn1); N3V_V (vel0, -=, norm1); /* Override body vectors */ SDOF_Overwrite_Motion (dt, vel0, omega0, theta0); } Message ( "\ncontact_props: Updated :: vel0 = (%f %f %f) vel1 = (%f %f %f)", vel0[0], vel0[1], vel0[2], vel1[0], vel1[1], vel1[2] ); } |
February 11, 2021, 06:33 |
Rep Power: 26 |
Have you already tried to just use this code in 3D? If so, what went wrong?
February 11, 2021, 09:24 |
Will Crawford-Jones
Rep Power: 5 |
Hi Pakk,
Thanks for the response. You're correct, maybe it should still work in 3D and I get an error for another reason, however, the error I get is this: 999999: mpt_accept: error: accept failed: No such file or directory . . (lots of repeats) . 999999: mpt_accept: error: accept failed: No such file or directory Node 2: Process 7064: Received signal SIGSEGV. 999999: mpt_accept: error: accept failed: No such file or directory 999999: mpt_accept: error: accept failed Node 7: Process 21496: Received signal SIGSEGV.: No such file or directory 999999: mpt_accept: error: accept failed: No such file or directory . . (lots of repeats) . 999999: mpt_accept: error: accept failed: No such file or directory 999999: mpt_accept: error: accept failed: No such file or directoryMPI Application rank 5 exited before MPI_Finalize() with status 2 The fl process could not be started. The part where it says "The fl process could not be started" I have noticed before in other parts of the forum, but not in this situation: MPI Application rank 0 exited before MPI_Finalize() with status 2 The fl process cou Personally, I think it's to do with the UDF not being compatible for 3D, but I may be wrong. Thank you |
February 11, 2021, 09:44 |
Rep Power: 26 |
Do you also get an error in serial mode?
February 11, 2021, 11:44 |
Will Crawford-Jones
Rep Power: 5 |
Running in serial mode seems to make the UDF work in 3D and I don't get the error, thanks for that! However, why is it that the UDF works in parallel for 2D but not 3D? Also, is it possible for me to edit the UDF such that it works in parallel for 3D?
February 11, 2021, 12:38 |
Rep Power: 26 |
I don't know that... Making a UDF parallel is not something I am good in, and the error messages are never helpful.
February 12, 2021, 04:05 |
Will Crawford-Jones
Rep Power: 5 |
OK, but as far as you know it is possible to do so? This is what I would have to do in order to make it work in parallel processing I guess.
Thanks |
March 15, 2021, 13:27 |
Hi wcj1n18,
Did you manage to modify the 2D Contact Detection UDF to work in 3D? If so, could you please provide me with some pointers on how to do it? Thank you! |
March 16, 2021, 06:35 |
#9 |
Will Crawford-Jones
Rep Power: 5 |
Hey,
I actually was over-complicating it. It seems to work in 3D anyway. That code just simply reflects the velocity in the same way that a ball would bounce of a wall. But yeah, it should work in 3D. |
March 17, 2021, 23:33 |
#10 |
Alexander
Rep Power: 34 |
there is no reason to make this code parallel
remove Code:
best regards ****************************** press LIKE if this message was helpful |
3 dimensions, contact detection, udf and programming, udf manual |
UDF for dynamic Contact Angle | Wolfgang.Black | FLOW-3D | 0 | May 26, 2020 15:20 |
Replicating Scalable Wall Function with a UDF | yousefaz | FLUENT | 0 | August 4, 2017 02:30 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
Contact angle UDF | shephali shrimali | FLUENT | 0 | May 10, 2007 07:52 |
UDF for dynamic contact angle | Aireen | FLUENT | 0 | August 11, 2006 11:08 |
