UDF heat flux boundary conditions (heat fulx - convective losses - radiation losses)
Like Tree1Likes
  • 1 Post By JMM_UC3M
Old   January 31, 2021, 06:27
Exclamation UDF heat flux boundary conditions (heat fulx - convective losses - radiation losses)
Jose Martin
JMM_UC3M is on a distinguished road
Hi folks,
I am creating my first UDF and I have a big problem, I do not understand how to read the face wall temperature . Can anyone help me?. The code is almost ready except how to input this temperature. Many thanks in advance.
PS: If i set up temperature at 500 K all calculus are ok, but I would need to read the real one!
UDF below!
#include "udf.h"
#define QMAX 407400 /* W/m2 */
#define EEPSILON 0.1
#define TAU 5.67e-8
#define T_AIRE 300
#define H_AIRE 40 /* convective coef.W/m2K */
/* profile for heat flux*/
DEFINE_PROFILE(heatflux_profile, t, i)
/* variable declaration */
real centroide[ND_ND]; /* vector position */
real x;
real y;
face_t f;
cell_t cell;
real seno; /* heat distribution */
real T_p; /* wall temperature */
begin_f_loop(f, t)
F_CENTROID(centroide,f,t);
x=centroide[0]; /* valor del cntroide en la componente x */
y=centroide[1]; /* valor del cntroide en la componente y */
seno=y/sqrt((x*x)+(y*y));
T_p = 500; /* I NEED TO FIND THE FUNCTION IN ORDER TO READ THE WALL TEMPERATURE */
if (0 < y)
F_PROFILE(f,t,i)=(QMAX*seno)+TAU*((T_p*T_p*T_p*T_p )-(EEPSILON*T_AIRE*T_AIRE*T_AIRE*T_AIRE))+H_AIRE*(T_ p-T_AIRE);
} else {
F_PROFILE(f,t,i)=0;
end_f_loop(f, t)
JMM_UC3M is offline   Reply With Quote
Old   January 31, 2021, 08:44
Jose Martin
Small correction:
#include "udf.h"
#define TAU 5.67e-8
#define T_AIRE 300
real x;
real y;
face_t f;
cell_t cell;
begin_f_loop(f, t)
T_p = 500; /* I NEED TO FIND THE FUNCTION IN ORDER TO READ THE WALL TEMPERATURE, DO NOT WHY F_T(f,t) DOES NOT WORK */
if (0 < y)
F_PROFILE(f,t,i)=(QMAX*seno)-TAU*((T_p*T_p*T_p*T_p )-(EEPSILON*T_AIRE*T_AIRE*T_AIRE*T_AIRE))-H_AIRE*(T_ p-T_AIRE);
} else {
F_PROFILE(f,t,i)=0;
end_f_loop(f, t)
Old   January 31, 2021, 08:59
pakk will become famous soon enough
You say F_T does not work, but can you be more specific? What happens if you do that?
pakk is offline   Reply With Quote
Old   January 31, 2021, 09:12
Jose Martin
Sure!! (btw many thanks!!! I am really stacked). And just one comment, the mesh I have is not good because I was trying to run the UDF and then I was gonna work on the mesh and so on, hope it is not the problem because when I set up T_p = 500 K it works...
Please find below the error , it seems it´s about the UDF in line 21
"Divergence detected in AMG solver: temperatureWarning: C:\\Users\\usuario\\Desktop\\udf\\heatflux_profile - copia (21).c: line 21: Warning: C:\\Users\\usuario\\Desktop\\udf\\heatflux_profile - copia (21).c: line 21: Warning: C:\\Users\\usuario\\Desktop\\udf\\heatflux_profile - copia (21).c: line 21:
Error at host: floating point exception
Warning: C:/Users/usuario/AppData/Local/Temp/heatflux_profile - copia (21).c.19192.0.c: line 21: Warning: C:/Users/usuario/AppData/Local/Temp/heatflux_profile - copia (21).c.19192.0.c: line 21: Warning: C:/Users/usuario/AppData/Local/Temp/heatflux_profile - copia (21).c.19192.0.c: line 21:
Error at Node 0: floating point exception
Error: floating point exception
Error Object: #f
Registering Udf, ("C:\Users\usuario\Desktop\udf\heatflux_profile - copia (21).c")
Calculation complete."
That´s the UDF I have used with the right function to read the wall temperature
#include "udf.h"
#define R 0.01
#define QMAX 40740 /* W/m2 */
#define TAU 5.67e-8
#define T_AIRE 300
#define H_AIRE 40
DEFINE_PROFILE(BC, t, i)
/* declaración de variables */
real centroide[ND_ND]; /* vector de posición */
real x;
real y;
face_t f;
cell_t cell;
real seno; /* para meter la distribucion de calor */
real T_p; /* temperatura de la pared */
begin_f_loop(f, t)
T_p = F_T(f,t);
if (0 < y)
F_PROFILE(f,t,i)=(QMAX*seno)-TAU*((T_p*T_p*T_p*T_p)-(EEPSILON*T_AIRE*T_AIRE*T_AIRE*T_AIRE))-H_AIRE*(T_p-T_AIRE);
} else {
F_PROFILE(f,t,i)=0;
end_f_loop(f, t)
Old   January 31, 2021, 12:21
Is that in the first iteration?
And try this: initialize your simulation, don't run, and plot the heat Flux on your relevant boundary. Is that what you expected?
Old   January 31, 2021, 13:19
Jose Martin
Hi Pakk, I think it was the mesh.... I cannot beleive it... I am running the simulation, but first checks seems good.... I will replay in a few hours heheheh.... I created a good mesh, but now I dont have the floating point (it was in the second iteration BTW)
pakk likes this.
Old   January 31, 2021, 15:56
Jose Martin
Just to close out this issue, I guess there were two different problems:
1) The mesh
2) just in case I created alll "z" coordinates in the positive side, just in case
Additionally, a pair of formulas were not ok, but it was not the problem... Below the UDF for a tube of a solar receiver, were you can see the heat flux, and the two losses (convective and radiation)
#include "udf.h"
#define EEPSILON 0.9
#define TAU 5.67e-8
#define T_AIRE 300
#define H_AIRE 40
DEFINE_PROFILE(receiver, t, i)
real x;
real y;
face_t f;
cell_t cell;
begin_f_loop(f, t)
T_p=F_T(f,t); /*500*/
if (0 < y)
F_PROFILE(f,t,i)=(QMAX*seno)-TAU*((T_p*T_p*T_p*T_p)-(EEPSILON*T_p*T_p*T_p*T_p))-H_AIRE*(T_p-T_AIRE);
} else {
F_PROFILE(f,t,i)=0;
end_f_loop(f, t)
PS: Thanks pakk
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
mixed boundary conditions including heat flux, convective heat transfer and radiation lotus_blue FLUENT 0 April 3, 2013 19:55
