define_on_demand being executed twice?
Like Tree2Likes
  • 2 Post By AlexanderZ
Old   January 25, 2021, 15:48
Default define_on_demand being executed twice?
jhz
jhz is on a distinguished road
I am using the define_on_demand macro for loading csv files into Fluent. After compiling the UDF and executing the define_on_demand macro manually, it appears to work successfully. However, using Message() to verify files are being read correctly always shows duplicate outputs, indicating the macro is somehow being run twice.
Testing with a very simple define_on_demand macro without file reading and just printing a message results in the same duplicate output. Why does this happen?
Thanks
jhz is offline   Reply With Quote
Old   January 25, 2021, 22:37
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
that's because fluent is running in parallel regime
so, probably, you have message from node_0 and host
dfsg250 and jhz like this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 26, 2021, 13:49
jhz
That makes sense - thank you!
How to calculate the number of if conditions executed in a fluent udf? Shubhamp Fluent UDF and Scheme Programming 56 January 23, 2020 19:19
[General] Paraview script executed by SGE grid engine iv_sc ParaView 0 December 10, 2015 11:22
code is being executed more than once per time step with different values Jinming Wu Fluent UDF and Scheme Programming 1 November 19, 2015 04:20
[dsmcFoam] Where is dsmcFieldsCalc executed? gautcho OpenFOAM 8 February 7, 2014 23:37
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
