Modelling an ohmic resistor heating a fluid via UDF
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   December 28, 2020, 03:02
Default Modelling an ohmic resistor heating a fluid via UDF
Hamish
ham551 is on a distinguished road
Hi there,
I am trying to model the heat transfer from an ohmic resistor in Argon. I don't want the resistor to interact with the fluid, so I would like to apply the heating rate via a UDF. I am new to UDF's and have written a basic one (shown below) applying a heat source to some generic zone inside the domain, but it doesn't seem to work. I have taken the coordinates when setting up the geometry in SpaceClaim ( At the moment the geometry is just a 2D rectangle with a pressure-inlet and pressure-outlet.)
Is there a problem with my code? And is there a better way to solve a problem like this in Fluent?
#include "udf.h"
DEFINE_SOURCE(sourceterm,c,t,dS,eqn)
real x[ND_ND];
real source;
C_CENTROID(x,c,t);
if(x[0]>=5 && x[0]<=10 && x[1]>=0 && x[1]<=12)
source=5000;
else
source=0;
return source;
ham551 is offline   Reply With Quote
Old   December 28, 2020, 06:34
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
the concept of code is correct, not sure about your condition statement
may be you should add more brackets
with one is working 100%:
if ((x[0]>=5) && (x[0]<=10))
	if (( x[1]>=0) && (x[1]<=12))
check units, check scale in Fluent, actually, if you everything in your model is in SI, 5 10 12 means 5 10 12 meters
5000 W/m3 is nothing for such huge zones
ham551 likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   December 29, 2020, 06:34
Hamish
Thanks for your help. I made those adjustments to my code and I also had to adjust the values of the bounds as my geometry is in mm, not m. A silly mistake by me.
However, the results I'm getting don't seem that accurate. For example for the below code, I get the following contour for source energy. As you can see the leading edge of the heat source is angular, while the trailing edge is square. I would expect the leading edge of the region to also be square for the bounds applied.
#include "udf.h"
real x[ND_ND];
real source;
C_CENTROID(x,c,t);
if ((x[1]>=0.005) && (x[1]<=0.006))
	if (( x[0]>=0.03 && x[0]<=0.04))
	{source=5000000;}
else
source=0;
return source;
If I use the x-coordinate in the first IF statement, for the same bounds, I get this utter mess.
#include "udf.h"
real x[ND_ND];
real source;
C_CENTROID(x,c,t);
if ((x[0]>=0.03) && (x[0]<=0.04))
	if (( x[1]>=0.005 && x[1]<=0.006))
	{source=5000000;}
else
source=0;
return source;
I don't understand how they can be so different as they are describing the same bounds as far as I can see.
Another issue I'm facing now, is I'm trying to expand my code to consider the heat source in a more sophisticated bounded region. I'm starting simple by trying to bound it within two linear lines. This is my code and resulting heat source contour. Again it's a mess. Any ideas?
#include "udf.h"
real x[ND_ND];
real source;
real m1;
real m2;
real c1;
real c2;
m1 = 1.22;
m2 = 1.22;
c1 = 0.01394;
c2 = 0.01619;
C_CENTROID(x,c,t);
if ((x[1]>=0) && (x[1]<=0.015))
	if ((x[0]>=(x[1] + c1)/m1) && (x[0]<=(x[1] + c2)/m2))
	{source=5000000;}
else
source=0;
return source;
Here's an image of the mesh for completeness.
Cheers
Old   December 29, 2020, 09:24
pakk will become famous soon enough
You omitted brackets in the second if.
If you go for a complex geometry, don't code it in a UDF. Just make two zones in your geometry, and apply the source only to one of your zones.
pakk is offline   Reply With Quote
Old   December 30, 2020, 06:31
Alexander
I have no idea, what are these contours, you suppose to have 5000000 in defined region
to plot your source add user defined memory, code will looks like this
#include "udf.h"
real x[ND_ND];
real source;
C_CENTROID(x,c,t);
		source=5000000;
		C_UDMI(c,t,0) = source;
else
source=0;
return source;
allocate 1 udm in fluent interface
best regards
Old   December 31, 2020, 13:06
Hamish
That works a lot better, thanks. Does it matter how I create a new zone? I just did a quick test and used a face split to create a new fluid zone. Works alright but looks like there might be an issue with the zone interfaces, the flow is doing weird things. Is it better practice to create two bodies and join them into a part and then mesh?
heat sources, udf source energy
Boundary Condition for wallHEatTransfer without modelling the Fluid Ohlzen-Wendy OpenFOAM Running, Solving & CFD 6 June 18, 2019 08:33
Divergence in non-Newtonian fluid UDF moabdi FLUENT 0 June 23, 2016 12:30
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 20:42
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
