Proper way to use cell/thread objects in UDF cell macros? |
December 14, 2020, 18:16 |
Rep Power: 6 |
I am using pre-defined cell macros (Fluent UDFs) to access flow field variables - such as C_U(c, t) for the u-velocity. I've included a code snippet to demonstrate the utilization. The exact application is less relevant to my problem, but to briefly explain it is an actuator-line model for a 3-bladed vertical axis wind turbine. The intended function of the code is to obtain (x,y,z) coords for actuator points and find a cell for which the distance between that coord and the cell centroid is minimum. Once it is found, I wanted to store the cell, thread references into the vars 'min_c' and 'min_t', to hopefully call later in a cell access macro like C_U(min_c, min_t). My question is: the following code when hooked to the simulation and run results in a 'Node ___ : Process ___ : Received Signal SIGSEGV' error, which I've found to be a segmentation fault. I was not able to find documentation on this error in general apart from specific posts, but through unit testing I've narrowed the problem to the macro calls in the 2nd last line -> 'C_U(min_c, min_t)' and 'C_W(min_c, min_t)'. Without these calls there is no error - meaning calling C_CENTROID() inside the cell loop according to the UDF manual is a correct implementation. Does this mean I cannot store cell_t and Thread object references from within the cell/thread loop and then outside of the loop use them in cell macros? Also, I have not been able to find relevant documentation in the UDF manual for Fluent, so I would be grateful for any resource you can provide documenting the nature/application of cell_t and Thread objects (I understand their basic definitions but they seemingly do not work like traditional programming objects). Any help is appreciated! Code:
#include "udf.h" #include <math.h> DEFINE_ADJUST(sample_code,d) { double PI = 3.14159265; int n_blades = 3; int n_points = 10; double theta_i[3] = {90*(PI/180), 210*(PI/180), 330*(PI/180)}; double theta; double rot_speed = 2*8/0.6; double x_p, y_p, z_p; double y_0 = 5.0; double span = 4.0; double radius = 0.6; real centroid_arr[ND_ND]; // loop over all blades and actuator points for (int n = 0; n < n_blades; n++) { for (int p = 0; p < n_points; p++) { // determine position of actuator point in global coordinates double ds = span/p; y_p = y_0 + 0.5*ds + p*ds; theta = theta_i[n] + rot_speed*CURRENT_TIMESTEP*N_TIME; x_p = radius*cos(theta); z_p = radius*sin(theta); // find (cell,thread) closest to actuator point Thread *t; cell_t c; int counter = 0; Thread *min_t; cell_t min_c; double dist; double min_dist; thread_loop_c(t,d) { begin_c_loop(c,t) C_CENTROID(centroid_arr, c, t); dist = sqrt(pow(centroid_arr[0] - x_p, 2) + pow(centroid_arr[1] - y_p, 2) + pow(centroid_arr[2] - z_p, 2)); if (counter == 0) { min_dist = dist; point_forces[n][p][0] = centroid_arr[0]; point_forces[n][p][1] = centroid_arr[1]; point_forces[n][p][2] = centroid_arr[2]; min_c = c; min_t = t; } else if (counter > 0) { if (dist < min_dist) { min_dist = dist; point_forces[n][p][0] = centroid_arr[0]; point_forces[n][p][1] = centroid_arr[1]; point_forces[n][p][2] = centroid_arr[2]; min_c = c; min_t = t; } } counter = counter + 1; end_c_loop(c,t) } // perform calculations double v_mag = sqrt(pow(C_U(min_c, min_t), 2) + pow(C_W(min_c, min_t), 2)); } |
December 15, 2020, 00:05 |
Rep Power: 27 |
I think it could be because the thread is a pointer.
min_t=t; Code:
*min_t=*t; |
December 15, 2020, 01:06 |
Alexander
Rep Power: 34 |
I think, you can do it, you can use this approach with c_min and t_min
problem my comes from the part, where you are defining cell/threads move this part out of loop Code:
// find (cell,thread) closest to actuator point Thread *t; cell_t c; int counter = 0; Thread *min_t; cell_t min_c; double dist; double min_dist; Segmentation error means you are trying to access variables, which are not defined (memory is not allocated), so may be there could be a case when non for your conditions are true: Code:
if (counter == 0) { Code:
best regards ****************************** press LIKE if this message was helpful |
December 15, 2020, 14:06 |
Rep Power: 6 |
Hi pakk,
I tried that, but unfortunately it doesn't work. |
December 15, 2020, 14:10 |
Rep Power: 6 |
Hi Alexander,
I tried doing what you suggested in the first part - moving the declarations outside of the loop, but the error still persists. I think it won't make a difference as long as the thread/cell definitions are outside of the tread/cell loops, correct? I'm not sure what you mean by the second half, relating to the if statements. Can you please clarify? Also, I think the way that Fluent iterates through the declared Thread *t object in the loops may be important. From the code itself, it seems as though thread_loop_c and begin_c_loop operates implicitly on the thread pointer and iterates through it somehow. Do you know anything more about the inner workings of this? (it's not described in the UDF manual) Thanks! |
December 15, 2020, 16:20 |
Rep Power: 27 |
Where and how did you declare point_forces?
December 15, 2020, 17:49 |
Rep Power: 6 |
I declared point_forces before DEFINE_ADJUST as a global double 3D array, but I think I missed that code declaration in the code snippet above. That's not the part causing problems, sorry for any confusion.
December 17, 2020, 03:43 |
Alexander
Rep Power: 34 |
may be your conditions are never true
your code: Code:
thread_loop_c(t,d) { begin_c_loop(c,t) { C_CENTROID(centroid_arr, c, t); dist = sqrt(pow(centroid_arr[0] - x_p, 2) + pow(centroid_arr[1] - y_p, 2) + pow(centroid_arr[2] - z_p, 2)); if (counter == 0) { min_dist = dist; point_forces[n][p][0] = centroid_arr[0]; point_forces[n][p][1] = centroid_arr[1]; point_forces[n][p][2] = centroid_arr[2]; min_c = c; min_t = t; } else if (counter > 0) { if (dist < min_dist) { min_dist = dist; point_forces[n][p][0] = centroid_arr[0]; point_forces[n][p][1] = centroid_arr[1]; point_forces[n][p][2] = centroid_arr[2]; min_c = c; min_t = t; } } counter = counter + 1; } end_c_loop(c,t) } Code:
thread_loop_c(t,d) { begin_c_loop(c,t) { min_c = c; min_t = t; C_CENTROID(centroid_arr, c, t); dist = sqrt(pow(centroid_arr[0] - x_p, 2) + pow(centroid_arr[1] - y_p, 2) + pow(centroid_arr[2] - z_p, 2)); if (counter == 0) { min_dist = dist; point_forces[n][p][0] = centroid_arr[0]; point_forces[n][p][1] = centroid_arr[1]; point_forces[n][p][2] = centroid_arr[2]; min_c = c; min_t = t; } else if (counter > 0) { if (dist < min_dist) { min_dist = dist; point_forces[n][p][0] = centroid_arr[0]; point_forces[n][p][1] = centroid_arr[1]; point_forces[n][p][2] = centroid_arr[2]; min_c = c; min_t = t; } } counter = counter + 1; } end_c_loop(c,t) } btw I don;t see brackets after begin_c_loop(c,t)
cell macro, convention, udf |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 12:04 |
Problem with cell macros | Abhinand | Fluent UDF and Scheme Programming | 0 | October 11, 2019 16:24 |
Calculating velocity gradients manually without any macros | NonStopEagle | Fluent UDF and Scheme Programming | 0 | September 25, 2019 11:29 |
how to store UDF output for arbitrary/particular cell | athalia | FLUENT | 1 | September 24, 2019 06:02 |
cell zone creation for degassing udf implementation | shahjehan | Fluent UDF and Scheme Programming | 0 | August 3, 2016 12:30 |
