Journal file UDF
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   November 27, 2020, 16:16
Default Journal file UDF
p.1
Italia
p.1 is on a distinguished road
Hi, there's a way to write a journal file for compiling a UDF (without hooking the function), run calculate for one time step, hooking the function and run calculate for other time steps?
p.1 is offline   Reply With Quote
Old   November 28, 2020, 02:42
pakk will become famous soon enough
Yes.
Use the TUI to find out which commands you need to use. Honestly, it's very annoying to do (everything has to be 100% correct to work), but it can be done, I have done similar things before.
I can not give concrete code, I'm sorry.
pakk is offline   Reply With Quote
Old   November 28, 2020, 03:14
p.1
Italia
Originally Posted by pakk View Post
Yes.
Where I can find the commands I have to use?
Old   November 28, 2020, 04:26
Press enter in the TUI, you get a menu with options. Think logically which submenu is most likely to have what you want, and continue from there.
Old   November 28, 2020, 04:27
p.1
Italia
Thank you.
Old   November 28, 2020, 05:50
p.1
Italia
I did it. Thank you.
Old   November 30, 2020, 00:12
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
(ti-menu-load-string (format #f "define user-defined compiled-functions compile? name_of_my_udf_library yes my_udf_source.c \n \n " ))
(ti-menu-load-string (format #f "solve initialize initialize-flow"))
(ti-menu-load-string (format #f "solve set t-s 1"))  ;;;timestep size 1 sec
(ti-menu-load-string (format #f "solve d-t-i 1 30"))  ;;;make 1 time step with 30 iterations inside
(ti-menu-load-string (format #f "define user-defined compiled-functions load name_of_my_udf_library" ))
(ti-menu-load-string (format #f "define user-defined function-hooks adjust  \"my_adjust_tebha::name_of_my_udf_library\" \n" ))
(ti-menu-load-string (format #f "solve set t-s 10"))  ;;;timestep size 10 sec
(ti-menu-load-string (format #f "solve d-t-i 100 30"))  ;;;make 100 time step with 30 iterations inside
zimao likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 36 July 16, 2024 04:52
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
