November 16, 2020, 13:06 |
Compiled UDF not showing up in Fluent?
unicorn
Rep Power: 6 |
I have successfully compiled the UDF in Fluent and the 'libudf' library was successfully created (build and load both with no errors) however when I try to apply the UDF to the cell zones it doesn't show up in the drop down box?
I have checked in the dynamic mesh section too and the UDF doesn't show up in the drop down boxes there either. Unsure where the problem is because there was no errors in the build and loading when compiling the UDF. I've attached a picture of the problem (ignore the very coarse mesh lol). Does anyone please have any solutions to this? Haven't seen this issue anywhere! Extra info: The libudf library has been saved to where the udf .c file is saved and the case files for my project are saved. The udf uses DEFINE_TRANSIENT_PROFILE returning theta_dot to change the pitch angle (theta) of blades as they rotate about an axis. |
November 16, 2020, 13:27 |
Rep Power: 27 |
What makes you say that compilation was successful?
I'm not saying you are wrong, but I have seen too many questions here where it was said the compilation gave no errors, and then it turned out that the compilation gave errors, the user just did not know where to look for them... |
November 16, 2020, 13:35 |
#3 | |
unicorn
Rep Power: 6 |
November 16, 2020, 16:37 |
Rep Power: 27 |
November 17, 2020, 02:28 |
Alexander
Rep Power: 34 |
press BUILD button, copy console output here
press LOAD button, copy console output here once you are pressing load, fluent shows you the list of functions defined in your UDF
best regards ****************************** press LIKE if this message was helpful |
transient profile, udf compile |
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle | FelixJJ | FLUENT | 2 | October 20, 2021 03:39 |
compiled udf functions at fluent 15 win 8 64 bit | hillat | Fluent UDF and Scheme Programming | 2 | January 25, 2014 08:08 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
UDF interpret in Fluent | wanghaojie | Fluent UDF and Scheme Programming | 1 | February 3, 2012 15:51 |
fluent UDF external library lapack problem | Rick | FLUENT | 0 | May 7, 2008 11:16 |
