Define_execute_at_end
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   November 8, 2020, 06:51
Default Define_execute_at_end
ArikGuyz is on a distinguished road
It is written in the UDF Manual that DEFINE_ADJUST macro is utilized in order to manipulate the flow variables, and it is called at the beginning of the each iteration or time step.
Can DEFINE_EXECUTE_AT_END macro be also used in order to change the flow variables, in particular velocity? As far as I understood, their difference is their sequence in the solution process. DEFINE_EXECUTE_AT_END macro is called at the end of the steady state iteration, or at the end of the time step; whereas DEFINE_ADJUST is at the beginning of them.
Can anybody clarify that?
Thanks in advance.
ArikGuyz is offline   Reply With Quote
Old   November 9, 2020, 01:26
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you've gotten it correct
ArikGuyz likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
