Error when running fluent through developer command prompt for VS |
November 3, 2020, 13:53 |
L.A.Isanka
Rep Power: 6 |
Hello!
My Fluent window is half loaded when I run it through the Developer command prompt for VS 2012. I have attached a snap of the window. Do you know how to fix this? Thank you [IMG]https://ibb.co/1qy282Z[/IMG] |
November 3, 2020, 14:59 |
Rep Power: 27 |
You have a space in your folder name (Rocky 4). Fluent does not like that.
November 4, 2020, 04:49 |
L.A.Isanka
Rep Power: 6 |
Hi Pakk,
Thank you for your reply. But there is no such rocky folder in my c folder and I'm confused with this path. Is that the reason for this? But it loads well when I launch fluent via the workbench. This only happens when running fluent through the developer command prompt for VS. |
November 4, 2020, 10:58 |
Rep Power: 27 |
You apparently have the file "C:\Users\Achini Liyanage\.fluent", which tells Fluent to open this macro. I don't know why you have that .fluent file, and I don't know what it is supposed to do, so I don't know if you can just remove it or not.
But I don't even know if this is a problem. You say it is "half-loaded", but I don't see anything half-loaded, it looks fully loaded. Did you try to ignore this warning and continue as if it was not there? |
command prompt, compiler, fluent - udf, visual studio |
Problem About Running Fluent In Linux | mitra | FLUENT | 18 | June 20, 2019 03:11 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 11:54 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 03:00 |
How can I track the progress of FLUENT when running ANSYS System Coupling | yhy20081016 | FLUENT | 1 | June 4, 2013 13:03 |
FLUENT 5.2.3 running on PIII 733 | Burley Wang | FLUENT | 7 | April 19, 2000 07:03 |
