temperature and pressure dependent specific heat (Cp) |
Amirreza Niazmehr
Rep Power: 7 ![]() |
Hi guys
I'm doing with plasma and Cp varies with T and P. Does anyone knows how add pressure dependence in DEFINE_SPECIFIC_HEAT? if it was dependent to only T it was easy, but now with T and P dependence i think UDF will work. Does anyone have any suggestion? Thanks alot |
ram
Rep Power: 13 ![]() |
The answer is late and would not be useful for you, but I am writing to others probably. It is written in fluent UDF guide V18 nodding that it can be temperature dependant only: "The DEFINE_SPECIFIC_HEAT macro can be used to define temperature-dependent functions for specific heat and sensible enthalpy for fluid, solid and mixture materials" I tried to write it based on pressure and there was an error during the compilation. it was discussed in the following link with apparently the same conclusion: temperature and pressure dependent specific heat? |
Amirreza Niazmehr
hi...Thanks for your reply.
But we did it by means of User-Defined Real Gas Model. Check here to get more informations. https://www.afs.enea.it/project/nept...ug/node337.htm All the best Amirreza |
Jack Zhang
Rep Power: 0 ![]() |
thank you, you have helped solve my problem.
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 02:54 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
