Can you solve UDS on a flow field, while not solving the flow field? |
October 7, 2020, 12:12 |
I want to solve an UDS in my domain. But I do not want to solve the flow field. I want to initialise the flow field for every timestep and then only calculate the UDS for one timestep (not NS-Eq). Is this even possible or is the solving of an UDS automatically coupled to multiple Iterations for solving u,v,w components. I want to do so, because my UDS has no influence on my flow field components u,v,w and it is very time consuming to calculate this behavior coupled. best regards, alex |
October 7, 2020, 23:07 |
Alexander
Rep Power: 34 |
Fluent Gui -> Solution -> Controls -> Equations -> switch off equations, you don't need (energy and flow for your case)
best regards ****************************** press LIKE if this message was helpful |
October 12, 2020, 14:44 |
that was too easy Thanks for that!
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 10:48 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 19:17 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 09:35 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 04:34 |
