What's the applicable scope of G and RG Vector Macros
Like Tree2Likes
  • 2 Post By AlexanderZ
Old   October 1, 2020, 08:28
Default What's the applicable scope of G and RG Vector Macros
lbj007 is on a distinguished road
In help manual: The gradients stored in variables with the _G suffix are non-limited values and if used to reconstruct values within the cell (at faces, for example), may potentially result in values that are higher (or lower) than values in the surrounding cells. Therefore, if your UDF needs to compute face values from cell gradients, you should use the reconstruction gradient (RG) values instead of non-limited gradient (G) values.
Can I explain it as " RG macros is more suitable than G macros",so what is the reason of defining G macros since RG is better? Or maybe G has some advantage I don't know. Maybe RG is only suitable when you use the second order discretization scheme? I wonder if someone can explain it
lbj007 is offline   Reply With Quote
Old   October 5, 2020, 02:40
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
RG is used to define gradient value on faces adjusted to cells
Gradient is calculated in the center of finite volume
lbj007 and Mary-31 like this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 5, 2020, 22:42
thanks,now I get it
gradient, reconstruction gradient
