i need to use density and volume fraction of each phase in Eulerian multiphase method
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   September 20, 2020, 07:36
Post i need to use density and volume fraction of each phase in Eulerian multiphase method
mohammad
movaffagh is on a distinguished road
i want to simulate boiling with Eulerian CHF or RPI boiling models. now i want to compile a udf for my simulation and i need the volume fraction,density and velocity of each phase. primary phase is wwater and secondary phase is vapor.
i know there are C_vof(c,t) and C_R(c,t) in udf manual but i think these macros give me vof and density in single phase or give me the mixture property. i should use vof and density from each phase.
how can i do it?
thank you
Mohammad
movaffagh is offline   Reply With Quote
Old   October 5, 2020, 04:27
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
look for THREAD_SUB_THREAD macro in Ansys Fluent Customization manual
movaffagh likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 5, 2020, 04:36
Post
mohammad
Hi, thank you AlexanderZ
is this macro help to me for seperate the value of each phase?
regards,
Mo.Movffagh
Old   October 5, 2020, 04:46
Alexander
yes
take a look at Custom Drag Law example
best regards
Old   October 5, 2020, 04:59
Post
mohammad
yes
can you give me a link for drag example?
my simulation is two phase and its boiling. how drag examples can help me?
regards,
Mo.Mvaffagh
Old   October 6, 2020, 04:34
Alexander
best regards
Old   October 13, 2020, 12:46
Default Response
Lamp
lampfall90@icloud.com is on a distinguished road
how can i do it?
thank you
Mohammad
Hello sir, please could you help me with the udf code for your problem if you get any resolution for the problem because I am dealing with gas liquid two phase in axial flow pump ? Thanks
lampfall90@icloud.com is offline   Reply With Quote
boiling flow, multi phase, property, udf code
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Is it possible that multi-phase flow shows gradation of volume fraction? kjh9537 Fluent UDF and Scheme Programming 0 June 23, 2017 15:16
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
