August 9, 2020, 00:16 |
Change the discretization form in fluent
Abhinand
Rep Power: 10 |
Is it possible to modify the diffusion term in the momentum equation and discretize it differently?
For eg: D d^2 u/dy^2 is discretized as (u_(i+1)-2u_i +u_(i-1))/dy^2 I want to write it as ((du/dy)_(i+1) - (du/dy)_(i))/Dy Where and how can I accomplish this in fluent? |
August 10, 2020, 02:57 |
Alexander
Rep Power: 34 |
as far as I know, you can change the scheme for all momentum equation only
what you need is in Solution Methods -> spatial discretization, Momentum -> First order Upwind other option is to define your own diffusion equation using user-define scalars In that case you may select spatial discretization separately
best regards ****************************** press LIKE if this message was helpful |
August 14, 2020, 21:44 |
Abhinand
Rep Power: 10 |
AlexanderZ,
Thanks for your reply. Do you mean to say, I can add a separate UDS equation and add to the velocity to get my new discretization. Lets say I discretize the diffusion term by B, and fluent by default discretizes by A The net momentum equation should be something like Fluent - A + B right? But how do I modify or write in the discretization equation, since modification only in that form will affect the velocity calculation and using UDF I can affect only the values of velocity. Please let me know your thoughts |
Fluent in Ansys Workbench : Change Working Directory | sral | FLUENT | 4 | March 29, 2019 11:29 |
Will a change in ER in PrePDF affect the diesel combustion(DPM Model Fluent) outcome? | Chidambaram Raju | FLUENT | 0 | January 12, 2016 06:21 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
Discretization settings Foam vs. Fluent | wuppdupp | OpenFOAM Pre-Processing | 6 | July 25, 2009 03:35 |
How to change background color in fluent | Venu Gopal | FLUENT | 4 | August 31, 2004 07:34 |
