UDF not running. Problem known but I can't solve it
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   August 5, 2020, 12:05
Default UDF not running. Problem known but I can't solve it
Deutschland
schwaral is on a distinguished road
Send a message via ICQ to schwaral Send a message via AIM to schwaral Send a message via Yahoo to schwaral
How can I adress the input arguments for c_vol? I need a cell value in my f_loop, but i don't know how to get the value. It would be enough to know the volume off the cell which belongs with one face to the boundary that I want to specify by define_profile. Any help would be great. Is the a solution to adress with pointers the cell of the face in normal direction maybe? Without the c_vol the code works great.
DEFINE_PROFILE(massfraction_for_const_RH,thread,po sition)
cell_t cell;
face_t f;
double a= -5800.2206;
double T,massfraction_new;
double p_sat, c_vol;
begin_f_loop(f,thread)
T=F_T(f,thread);
c_vol = C_VOLUME(cell, thread);
p_sat= exp(a*pow(T,-1));
massfraction_new=0.7*p_sat/c_vol;
F_PROFILE(f,thread,position)=massfraction_new;
end_f_loop(f,thread)
schwaral is offline   Reply With Quote
Old   August 6, 2020, 05:03
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
try this code, compile it
DEFINE_PROFILE(massfraction_for_const_RH,t,i)
cell_t c,c0;
face_t f;
Thread *t0;
real a= -5800.2206;
real T,massfraction_new;
real p_sat, c_vol;
begin_f_loop(f,t)
T=F_T(f,t);
c0 = F_C0(f,t);
t0 = F_C0_THREAD(f,t);
c_vol = C_VOLUME(c0, t0); /*get volume of cell adjusted to face */
F_PROFILE(f,t,i)=massfraction_new;
end_f_loop(f,t)
snow.shaoy likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   August 6, 2020, 07:06
Deutschland
Thanks a lot AlexanderZ for the reply!
Unfortunately this does not work. The Error is: structure reference not implemented
in the following line: t0 = F_C0_THREAD(f,t);
I like your idea using the Connectivity Variables. Somehow I can't find a post where someone used DEFINE_PROFILE in combination with a cell_value of the boundary cells one tries to modify.
best regards,
Alex
Old   August 13, 2020, 10:31
Deutschland
I am very sorry for my previous answer. Your solutioon works perfect. I did not read, that you have to compile it. Instead i tried with interpreting.
Thanks again!
cell value, define profile, loop, udf
UDF problem for Population balance model Amir.11 Fluent UDF and Scheme Programming 6 May 30, 2022 05:36
Problem with running UDF of linux Tomsho Fluent UDF and Scheme Programming 2 June 12, 2019 13:59
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
Can I use UDF function to solve this problem? bright181 Fluent UDF and Scheme Programming 3 December 10, 2010 05:46
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 06:29
