Problem with pitch rotation and translational acceleration in udf
Like Tree2Likes
  • 1 Post By AlexanderZ
Old   July 16, 2020, 06:54
Default Problem with pitch rotation and translational acceleration in udf
Outside US and Canada
Rabeyia Manzoor Illahi is on a distinguished road
I have to make a udf of the following two equations but unable to get the movement for omega, if you can please help.
#include "udf.h"
DEFINE_CG_MOTION(air,dt,vel,omega,time,dtime)
Thread *t;
face_t f;
real tau,delTau,Tau1, pi, U, c, Taur;
pi = 3.14159265;
U=1;
c=1;
/*time=time+dtime;*/
tau=(time*U)/c;
delTau = (dtime*U)/c; /*(dtime*U)/c*/;
Tau1= (time*U)/c;/*(time1*U)/c*/;
Taur= Tau1-delTau;
vel[0] = 0.5*(1+cos(pi*(tau-Tau1)/delTau));
omega[2] = 77.5*(1-cos(2*pi*(tau-Taur)/delTau));
Rabeyia Manzoor Illahi is offline   Reply With Quote
Old   July 17, 2020, 01:52
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
cos(2*pi) = 1
so omega[2] = 77.5*(1- 1) = 0 always
modify your equation
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   July 17, 2020, 02:05
Sir thankyou so much for thr reply. But the cos function also involves other terms so it wont be zero.
And I have take these equations from a paper of "Unsteady aerodynamic force generation by a model fruit fly wing in flapping
motion" by Sun and Tang.
If you can please help.
Old   July 17, 2020, 02:13
Alexander
put
tau=(time*U)/c;
Taur= Tau1-delTau;
in
best regards
Old   July 17, 2020, 02:24
Sir if I run the omega equation alone, its working but both velocity and omega not working together. If you can please help.
Old   July 17, 2020, 03:40
Alexander
how it could works if omega[2] = 0 ????
check the difference between codes
did you compile UDF? this is must for DEFINE_CG_MOTION macro
for more informaton about dynamic mesh you may check Ansys Fluent Customization manual -> Dynamic Mesh DEFINE Macros chapter
best regards
