July 15, 2020, 20:46 |
Temperature field without energy option
ShOh
Rep Power: 6 |
Hello.
I want to obtain the temperature field without 'Energy' option in the 'models'., i.e. with 'Energy (off)'. For this, I tried to use a user-defined scalar equation, but I'm not sure how to use it. I would really appreciate it if you let me know. Also, if we are solve the RANS equations for the flow field, we may solve the mean scalar equation for the passive scalar (temperature) together with the gradient-diffusion hypothesis. Then, how can I set the turbulent diffusivity ratio (in this case, turbulent Prandtl number(=alpha_t/nu_t))?? If possible, I would also appreciate providing uds script. Thank you. |
July 16, 2020, 01:50 |
Alexander
Rep Power: 34 |
best regards ****************************** press LIKE if this message was helpful |
July 16, 2020, 03:24 |
ShOh
Rep Power: 6 |
Thank you.
prandtl number, turbulent diffusivity, uds |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 03:54 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
