Defining UDF for boundary with varying velocity |
June 8, 2020, 13:21 |
sina hassanpoor
Rep Power: 7 |
hi
i want to set up a simulation for a tank with varying velocity boundary. the velocity depends on the tank pressure. velocity is a power law function of pressure in tank and also the tank is expanding(the wall is moving). 1-what UDF should i use? 2- can i use "named expression" in UDF?( i defined an average pressure in named expression and i want my UDF to be able to read this average pressure.) 3- when i define the mass flow rate as an expression, this error shows up {Incorrect expression unit. Expression Unit [m s^-1], Required Unit [m s^-1]}. the dimensions are correct and error seems unreasonable. have you ever encountered this problem? |
June 9, 2020, 02:05 |
Alexander
Rep Power: 34 |
1. if you are going to use UDF read Ansys Fluent Customization manual, look for DEFINE_PROFILE macro
2. if you are going to use UDF, you may define all boundary conditions here. Or calculate pressure again 3. show expression which you put
best regards ****************************** press LIKE if this message was helpful |
June 9, 2020, 07:49 |
sina hassanpoor
Rep Power: 7 |
this is my expressions i defined, can i use one of my expressions like "P_avg" in UDF profile?
June 15, 2020, 05:23 |
Udf
I am unsure if the expression could be used if it depends on another expression that uses field values, such as, pressure in the domain.
Prefer UDF. For most of the boundary conditions, you need to use DEFINE_PROFILE. Since the pressure in the tank is not a single value, you need to reduce it to a scalar, either using an average or maximum or minimum, depending upon your requirement.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
UDF inlet velocity by UDF not the same as via GUI? | h0rst | Fluent UDF and Scheme Programming | 0 | April 24, 2017 02:45 |
Creating UDF with changing velocity with time | jabeztan | Fluent UDF and Scheme Programming | 8 | March 9, 2017 10:46 |
Creating UDF with changing velocity with time | jabeztan | Main CFD Forum | 0 | March 8, 2017 12:34 |
Simulation with UDF for species mass fraction and velocity profile | virgy | Fluent UDF and Scheme Programming | 8 | February 7, 2012 05:30 |
UDF for varying inlet velocity with z-distance | Peter Wilkins | FLUENT | 1 | May 18, 2006 12:10 |
