UDF for Flexible Airfoil
Like Tree2Likes
  • 1 Post By vinerm
  • 1 Post By vinerm
Old   May 1, 2020, 10:58
Default UDF for Flexible Airfoil
JoshnaJayes21
JoshnaJayes21 is on a distinguished road
I'm doing a simulation on ansys fluent for a flexible airfoil. Can you please suggest a UDF for that?
JoshnaJayes21 is offline   Reply With Quote
Old   May 1, 2020, 16:13
Default Udf
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
You question is little ambiguous. What do you need UDF for?
JoshnaJayes21 likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 2, 2020, 05:39
JoshnaJayes21
Thank you very much for the reply 😊.
I want to make the airfoil to a flexible type and the mesh to a deforming type. I'm new to ansys so I watched some videos and found out that they are using udfs. I'm not certain about what to do.😐
Old   May 2, 2020, 17:04
Default Flexible Airfoil
vinerm's Avatar
Vinerm
There are two ways to simulate a flexible airfoil and it all depends on the objective. If the deformation is caused by the Fluid, then you have to do an FSI simulation and a UDF may not be required. However, if the objective is to study the effects of an oscillating airfoil on fluid around it, then you can use UDF to model the motion of the airfoil. However, the motion needs to be described by an equation and UDF has to be written for that equation. There are no generic UDFs.
Regards,
Vinerm
Old   May 3, 2020, 09:35
JoshnaJayes21
Thank you for your suggestions 😊.
I'll try the FSI simulation.
flexible airfoil, udf
seek airfoil c udf code file,like:CG-motion.c Lingyu Fluent UDF and Scheme Programming 2 March 28, 2018 10:10
UDF for Heaving airfoil alireza_b FLUENT 0 June 3, 2015 16:40
UDF for pitching and rotating airfoil guidofrate Fluent UDF and Scheme Programming 0 November 20, 2014 09:32
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 07:12
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 19:36
