3D UDF for rectangular domain inlet
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   March 31, 2020, 20:03
Default 3D UDF for rectangular domain inlet
AL AMEEN AHMED RUFAI
aar007 is on a distinguished road
Hi, I am trying to model a UDF for my wind tunnel inlet using power law.
1; when I try computing my inlet conditions from in reference value I get *nan* in velocity section
(#include "udf.h"
#define P 1./7. //power law n value 7//
#define uref 1.32 // m higeht of inlet//
DEFINE_PROFILE(inlet_x_velocity, thread, position)
real x[ND_ND]; /* this will hold the position vector */
real z;
face_t f;
begin_f_loop(f, thread)
F_CENTROID(x,f,thread);
z = x[2];
F_PROFILE(f, thread, position) = 40*pow(z/uref,P);
end_f_loop(f, thread)
2; I get the same issue and error when I try using the function expression.
uref [m s^-1] * (z / z_ref [m]) ** alpha3.my inlet is at x=-1 using magnitude and direction under velocity specification method
aar007 is offline   Reply With Quote
Old   April 1, 2020, 04:10
Default Udf
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The UDF is alright and you can use it. However, this cannot be used for initialization. DEFINE_PROFILE is not executed before initialization. You have to initialize by providing some value for the velocity.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 11, 2022, 08:06
Ved prakash
ved prakash is on a distinguished road
Hi, have you found the solution?? I am also trying to use this expression. Please help me out.
ved prakash is offline   Reply With Quote
Old   May 11, 2022, 23:58
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
solution is written by vinerm one line above
ved prakash likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Turbomachinery Mass imbalance sheaker CFX 12 September 5, 2019 09:09
Ansys Fluent UDF, Wall Average Temperature Depend On Inlet Velocity ozgeozge Fluent UDF and Scheme Programming 1 April 15, 2019 02:31
Fluent UDF wrong number of cells in parallel - correct in serial dralexpe Fluent UDF and Scheme Programming 7 May 17, 2018 09:26
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Reduced domain/ Pressure inlet to velocity inlet victoryv FLUENT 1 June 29, 2013 15:45
