Velocity Cell Macros in 2D Axisymmetric Swirl
Like Tree1Likes
  • 1 Post By vinerm
Old   February 14, 2020, 08:16
Default Velocity Cell Macros in 2D Axisymmetric Swirl
c_023 is on a distinguished road
Does anyone know how the velocity components can be accessed with a macro in 2D axisymmetric swirl? The UDF manual does not differ between 3D and 2D axisymmetric and only provides C_U(c,t), C_V(c,t), C_W(c,t). Are there specific macros for accessing Velocity components in axisymmetric and axisymmetric swirl domain?
I have a UDF that is using Velocity components to compute a source term, the UDF works well in 3D but is causing a SIGSEGV during the first Iteration in 2D axisymmetric swirl, which I believe stems from the UDF trying to Access a velocity component that is not existing.
Does anyone know what macros can be used in such a case?
Thanks in Advance and Kind regards!
c_023 is offline   Reply With Quote
Old   February 14, 2020, 11:37
Default Sigsegv
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
C_W exists for a case with 2D axisymmetric swirl. Check your code; it's possible that the error is due to some other reason.
c_023 likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Swirl component in inflow BC for 2d axisymmetric flows vishalsacharya OpenFOAM Pre-Processing 2 November 2, 2018 06:33
Macros for cell volume particle is in DPM (fluent 18.1) skumar112 Fluent UDF and Scheme Programming 11 March 28, 2018 11:19
swirl inlet velocity for a 2-d axisymmetric flow zahrarashidi OpenFOAM Running, Solving & CFD 2 January 12, 2015 08:01
Axisymmetric Swirl Arpit Tiwari Main CFD Forum 1 September 15, 2010 06:45
Cell velocity in an axisymmetric problem Joc FLUENT 0 June 1, 2006 10:40
