UDF for laser Keyhole problem
Like Tree2Likes
  • 2 Post By AlexanderZ
Old   January 21, 2020, 10:46
Default UDF for laser Keyhole problem
eddy94 is on a distinguished road
Hi everyone,
I'm modeling an heat source for laser welding; I'm trying to model the keyhole volumetric distribution in a simple workpiece.
Once I created the UDF I gave it to the source term of the workpiece and I run the simulation but fluent always give me this error message:
"# Divergence detected in AMG solver: temperature -> Increasing relaxation sweeps!
# You may try the enhanced divergence recovery with (rpsetvar 'amg/protective-enhanced? #t)
Error: Divergence detected in AMG solver: temperature
Error Object: #f"
I really don't know what is the problem. This is my UDF:
/***** LASER HEAT SOURCE *****/
#include "udf.h"
#define EffL 0.85
#define Flas 3
#define Zkey 1.8
#define Zi 0.45
#define Plas 2000
#define CHIlow 0.5
#define CHIupp 0.5
#define PI 3.141592654
#define X0 15
DEFINE_PROFILE(heatflux_laser,thread, position)
real r[ND_ND];
real x, y, qlas,z,d,Rlas,Ri,Re;
cell_t c;
begin_c_loop(c, thread)
C_CENTROID(r, c, thread);
x= r[0];
y= r[1];
z= r[2];
if (z>=0 && z<Zi)
Rlas = Ri + ((Ri-Re)/Zi)*(z-Zi);
Ri = Rlas;
Re = 2*Rlas;
d = sqrt((x-X0)*(x-X0)+(y*y));
qlas = (CHIupp*EffL*Flas*Flas*Plas)/(PI*(1-exp(-3))*Zi*((Ri*Ri)+(Ri*Re)+(Re*Re)))*exp(-(Flas*d*d)/(Rlas*Rlas));
else if (z>=Zi && z<Zkey)
qlas = (CHIlow*EffL*Plas)/(PI*Ri*Ri*(Zkey-Zi));
else
qlas = 0;
C_PROFILE(c, thread, position)= qlas;
end_c_loop(c, thread)
If someone can help me would be awsome! Thanks to everyone in advance
eddy94 is offline   Reply With Quote
Old   January 22, 2020, 02:12
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
line 35:
Ri and Re are not defined
compile your code an read logs
anoop.k.unni and eddy94 like this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 22, 2020, 10:39
Thank you very much for your fast responce. Now my problem is solved, god bless you!
fluent - udf, laser welding, udf code
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. Ari Fluent UDF and Scheme Programming 4 May 31, 2016 09:51
udf loading problem santu Fluent UDF and Scheme Programming 1 May 22, 2015 16:47
Vaporization pressure UDF property problem? lehoanganh07 Fluent UDF and Scheme Programming 1 September 13, 2014 11:59
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 07:56
