Passing an array from one macro to another in a UDF while running in parallel |
Rep Power: 11 ![]() |
Hi guys! The following code represents what I am trying to achieve in a much larger and more complicated UDF for a multiphase simulation in parallel.
I am assigning values to globally declared array A in a DEFINE_ADJUST macro. I am trying to pass the array A from the DEFINE_ADJUST macro to the DEFINE_PROFILE macro and display its values in the DEFINE_PROFILE. The problem is that I am running the simulation in parallel, and any global variable/array gets initialized to 0 in a different macro. I have tried using host_to_node, etc. and PRF_CSEND, etc. but it hasn't worked out. Please help! Code:
#include "udf.h" int n = 10; int A[n]; DEFINE_PROFILE(foo, bar, oof) { int p = 0; for(p = 0; p < n; p++) { Message("%d\n", A[p]); } } DEFINE_ADJUST(foobar, barfoo) { int k = 0; #if !RP_HOST for(k = 0; k < n; k++) { A[k] = 10*k; } #endif } |
Alexander
Rep Power: 34 ![]() ![]() |
this code should work with no error
best regards ****************************** press LIKE if this message was helpful |
Thanks for taking the time to reply, AlexanderZ.
The code runs without any errors, but the values of array A[z] which I assign in the DEFINE_ADJUST don't get carried over to the DEFINE_PROFILE. So the Message function prints 0 0 0 0 instead of 10 20 30 ...etc. |
#4 | |
Alexander
Hi AlexanderZ! Sorry for the late reply.
In the following code I want to pass the values of yo[] and uo[] from the DEFINE_ADJUST to the DEFINE_PROFILE. Code:
DEFINE_PROFILE(x1_velocity,t,i) { int n=0; face_t f; real r, R, y, x, utp, tin, tip, U1; real xc[ND_ND];/*This will hold the position vector*/ real xc2[ND_ND];/*This will hold the position vector*/ real time_step=RP_Get_Integer("time-step"); tin= CURRENT_TIME; tip= PREVIOUS_TIME; // int IDi=7;/*Zone ID for intlet zone from Boundary Conditions task page*/ /* Send the ID value to all the nodes */ // host_to_node_int_1(IDi); /* Does nothing in serial */ R=0.0005;/*The radius of tube in m*/ utp=0.1; U1 = 0.2; #if !RP_HOST if ((time_step)<5) { begin_f_loop(f,t) { if PRINCIPAL_FACE_P(f,t) { F_CENTROID(xc,f,t); x=xc[0]; y=xc[1]; r=y/R; /*non-dimensional y coordinate*/ F_PROFILE(f,t,i)= 2*((U1+utp*(cos(omega*(tin-0.024995))))*(1-(r*r))); } } end_f_loop(f,t) } else if ((time_step)>=5) { begin_f_loop (f,t) { if PRINCIPAL_FACE_P(f,t) { F_CENTROID(xc2,f,t); for (n=0;n<65;n++) { if (n == 0) Message("I am in DEFINE_PROFILE(x1_velocity,t,i)\n"); if (n < 5) Message("yo[%d] = %f\n", n, yo[n]); if ((fabs(xc2[1]-yo[n]))<0.000000001) { F_PROFILE (f,t,i) = ((U1+utp*(cos(omega*(tin-0.024995)))))/((U1+utp*(cos(omega*(tip-0.024995)))))*(uo[n]); } } } } end_f_loop (f,t) } #endif } DEFINE_ADJUST(outlet1_store,domain) { real FC1[2]; face_t f; int IDo=10;/*Zone ID for outlet zone from Boundary Conditions task page*/ Thread *thread=Lookup_Thread(domain,IDo); real areao=0.0, uao=0.0; real NV_VEC(A); int p=0; /* Send the ID value to all the nodes */ // host_to_node_int_1(IDo); /* Does nothing in serial */ #if !RP_HOST begin_f_loop(f,thread) { if PRINCIPAL_FACE_P(f,thread) { F_CENTROID(FC1,f,thread); yo[p]=FC1[1]; if (p == 0) Message("I am in DEFINE_ADJUST(outlet1_store,domain).\n"); if (p<5) Message("yo[%d] = %f\n", p, yo[p]); uo[p]=F_U(f,thread); vo[p]=F_V(f,thread); to[p]=F_T(f,thread); areao +=F_AREA(A,f,thread); uao +=(F_U(f,thread))*(NV_MAG(A)); p+=1; } } end_f_loop(f,thread) # if RP_NODE /* Perform node synchronized actions here Does nothing in Serial */ areao = PRF_GRSUM1(areao); uao = PRF_GRSUM1(uao); # endif /* RP_NODE */ #endif uavgo=(uao/areao); } I am in DEFINE_PROFILE(x1_velocity,t,i) yo[0] = 0.000000 yo[1] = 0.000000 yo[2] = 0.000000 yo[3] = 0.000000 yo[4] = 0.000000 ...... I am in DEFINE_PROFILE(x1_velocity,t,i) yo[0] = 0.000000 yo[1] = 0.000000 yo[2] = 0.000000 yo[3] = 0.000000 yo[4] = 0.000000 I am in DEFINE_ADJUST(outlet1_store,domain). yo[0] = 0.000277 yo[1] = 0.000263 yo[2] = 0.000248 yo[3] = 0.000233 yo[4] = 0.000218 The yo[] values are different in the two macros. Please help. |
Alexander
you've showed only part of code, I can't compile it
you've showed modified output, wtf? if you are running in parallel, you should have several SAME lines in output, if you are using this code however you may try to add this code to your UDF Code:
#include "udf.h" DEFINE_PROFILE(x1_velocity,t,i) { int n=0; face_t f; real r, R, y, x, utp, tin, tip, U1; real xc[ND_ND];/*This will hold the position vector*/ real xc2[ND_ND];/*This will hold the position vector*/ real time_step; tin= CURRENT_TIME; tip= PREVIOUS_TIME; #if !RP_NODE /* SERIAL or HOST */ time_step=RP_Get_Integer("time-step") #endif /* !RP_NODE */ host_to_node_int_1(time_step); // int IDi=7;/*Zone ID for intlet zone from Boundary Conditions task page*/ /* Send the ID value to all the nodes */ // host_to_node_int_1(IDi); /* Does nothing in serial */ #if !RP_HOST /* SERIAL or NODE */ R=0.0005;/*The radius of tube in m*/ utp=0.1; U1 = 0.2; if ((time_step)<5) { begin_f_loop(f,t) { if PRINCIPAL_FACE_P(f,t) { F_CENTROID(xc,f,t); x=xc[0]; y=xc[1]; r=y/R; /*non-dimensional y coordinate*/ F_PROFILE(f,t,i)= 2*((U1+utp*(cos(omega*(tin-0.024995))))*(1-(r*r))); } } end_f_loop(f,t) } else if ((time_step)>=5) { begin_f_loop (f,t) { if PRINCIPAL_FACE_P(f,t) { F_CENTROID(xc2,f,t); for (n=0;n<65;n++) { if (n == 0) Message("I am in DEFINE_PROFILE(x1_velocity,t,i)\n"); if (n < 5) Message("yo[%d] = %f\n", n, yo[n]); if ((fabs(xc2[1]-yo[n]))<0.000000001) { F_PROFILE (f,t,i) = ((U1+utp*(cos(omega*(tin-0.024995)))))/((U1+utp*(cos(omega*(tip-0.024995)))))*(uo[n]); } } } } end_f_loop (f,t) } #endif /* !RP_HOST */ } DEFINE_ADJUST(outlet1_store,domain) { real FC1[2]; face_t f; int IDo=10;/*Zone ID for outlet zone from Boundary Conditions task page*/ Thread *thread=Lookup_Thread(domain,IDo); real areao=0.0, uao=0.0; real NV_VEC(A); int p=0; /* Send the ID value to all the nodes */ // host_to_node_int_1(IDo); /* Does nothing in serial */ #if !RP_HOST begin_f_loop(f,thread) { if PRINCIPAL_FACE_P(f,thread) { F_CENTROID(FC1,f,thread); yo[p]=FC1[1]; if (p == 0) Message("I am in DEFINE_ADJUST(outlet1_store,domain).\n"); if (p<5) Message("yo[%d] = %f\n", p, yo[p]); uo[p]=F_U(f,thread); vo[p]=F_V(f,thread); to[p]=F_T(f,thread); areao +=F_AREA(A,f,thread); uao +=(F_U(f,thread))*(NV_MAG(A)); p+=1; } } end_f_loop(f,thread) #endif # if RP_NODE /* Perform node synchronized actions here Does nothing in Serial */ areao = PRF_GRSUM1(areao); uao = PRF_GRSUM1(uao); # endif /* RP_NODE */ uavgo=(uao/areao); }
array, multiphase flow, parallel code |
[snappyHexMesh] Problem with boundaries with sHM in parallel running | Loekatoni | OpenFOAM Meshing & Mesh Conversion | 0 | January 24, 2019 07:56 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
Running parallel case after parallel meshing with snappyHexMesh? | Adam Persson | OpenFOAM Running, Solving & CFD | 0 | August 31, 2015 22:04 |
UDF could not be used in parallel by batch file, but could be used in single running | 768643480 | Fluent UDF and Scheme Programming | 2 | March 24, 2015 07:44 |
UDF for Species Mass Fraction Gradient *IN SPECIFIC ZONE * -- e.g. along axis of sym. | ksiegs2 | Fluent UDF and Scheme Programming | 0 | February 27, 2011 12:55 |
