Gaussian distribution for radiation BC
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   January 14, 2020, 16:43
Default Gaussian distribution for radiation BC
kawkab is on a distinguished road
I'm new to using UDF and I'm trying to write source code to set a 2D Gaussian distribution for the radiation flux as a BC.
Here is a basic code I wrote but for some reason, it doesn't distribute the flux correctly.
# include <math.h>
#include "udf.h"
# define x_m 0
# define y_m 0
# define i_m 6750000
DEFINE_PROFILE(radiation_flux, thread, position)
int x[ND_ND]; /* this will hold the position vector */
face_t f;
begin_f_loop(f, thread)
F_CENTROID(x, f, thread);
F_PROFILE(f, thread, position) = i_m * exp(-1 * ((((x[0] - x_m) ^ 2) / 2) + (((x[1] - y_m) ^ 2) / 2)));
end_f_loop(f, thread)
kawkab is offline   Reply With Quote
Old   January 14, 2020, 19:01
Svetlana Tkachenko
Svetlana is on a distinguished road
Does it compile? Could you please attach a contour of the flux that you receive?
Svetlana is offline   Reply With Quote
Old   January 14, 2020, 22:54
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
#include "udf.h"
must be in the first line
compile your code and read errors
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 15, 2020, 05:58
It's compiled without any error. I placed the #include "udf.h" in the first line but I still get a constant radiation intensity after initializing the solution (see attached image).
Old   January 16, 2020, 05:46
Alexander
show exact code which you are using and which is compiled without errors from your point of view,
show compilation log
best regards
Old   January 22, 2020, 07:36
The compilation log is as follows:
HTML Code:
Copied C:\Workspace\Ansys\Steadyhalf_files\dp0\FFF-3\Fluent/C:\Workspace\Ansys\Steadyhalf_files\dp0\FFF-3\Fluent\Source2.c to libudf\src
Creating user_nt.udf file for 3d ...
(system "copy "C:\PROGRA~1\ANSYSI~1\v171\fluent"\fluent17.1.0\src\udf\makefile_nt.udf "libudf\win64\3d\makefile" ")
        1 file(s) copied.
(chdir "libudf")(chdir "win64\3d")# Generating ud_io1.h
Source2.c
# Generating udf_names.c because of makefile Source2.obj
udf_names.c
# Linking libudf.dll because of makefile user_nt.udf udf_names.obj Source2.obj
Microsoft (R) Incremental Linker Version 14.24.28314.0
Copyright (C) Microsoft Corporation.  All rights reserved.
   Creating library libudf.lib and object libudf.exp
Done.#
And the code is:
#include "udf.h"
# include <math.h>
# define x_m 0
# define y_m 0
# define stdv 5
# define M_PI 3.14159265358979323846
DEFINE_PROFILE(radiation, t, i)
	face_t f;
	begin_f_loop(f, t)
		F_CENTROID(x, f, t);
		F_PROFILE(f, t, i) = i_m * (exp(-1 * ((((x[0] - x_m) ^ 2) / 2) + (((x[1] - y_m) ^ 2) / 2))));
		/*F_PROFILE(f, t, i) = i_m*(1/(2*M_PI*stdv))*exp(-1*(((x[0]-x_m)^2+(x[1]-y_m)^2)/(2*stdv^2)));*/
Old   January 22, 2020, 07:38
The compilation log is:
HTML Code:
1 file(s) copied.
Source2.c
udf_names.c
Done.
While the exact code is:
# #include "udf.h"
# include <math.h>
# define x_m 0
# define y_m 0
# define stdv 1
	face_t f;
	begin_f_loop(f, t)
	end_f_loop(f, t)
Old   January 22, 2020, 09:40
Let me clarify what I'm actually doing. It's a 3D fluent case and I'm trying to impose radiation flux on a circular boundary (window) with a 2D Gaussian distribution.
I compiled the previous code as a UDF and used it as a BC for direct radiation for the window. After I initialized the solution, the radiation intensity on the window becomes constant. But after running the solution for a few iterations, it takes a strange distribution (see the front view in the attached image).
Old   January 23, 2020, 00:05
Alexander
# include "udf.h"
# include <math.h>
# define x_m 0
# define y_m 0
# define stdv 1
	face_t f;
	begin_f_loop(f, t)
		F_PROFILE(f, t, i) = i_m*(1/(2*M_PI*stdv))*exp(-1*((pow((x[0]-x_m),2)+pow((x[1]-y_m),2))/(2*pow(stdv,2))));
	end_f_loop(f, t)
kawkab likes this.
best regards
UDF for 2D gaussian distribution slek Fluent UDF and Scheme Programming 13 January 14, 2020 22:52
size distribution models in OpenFOAM 4.x minzhang OpenFOAM Running, Solving & CFD 1 March 30, 2018 19:10
UDF program for gaussian distribution in space, time and both khattaksadia Fluent UDF and Scheme Programming 0 April 18, 2017 02:39
Diameter distribution, Search for options ?! souria FLUENT 0 January 22, 2016 09:38
maintaining a logarithmic velocity distribution Morten Andersen CFX 1 January 8, 2007 12:37
