UDF function for valve open following time
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   January 6, 2020, 01:27
Default UDF function for valve open following time
Nguyen Duy Trong
ndtrong is on a distinguished road
Hi everyone,
I am newbie in UDF function, then I have a question want to ask you.
If possible, could you please help me or explain to me the method to do.
I have two tanks with different presssure connected via pipe with valve. Valve will be opened following physical time as the attached image.
Now, I want to simulate the flow field in hole system.
I understand that I need to create UDF function for valve opening, however, I lack of experience in this step.
Could someone give me a help.
I thank you very much
ndtrong is offline   Reply With Quote
Old   January 6, 2020, 04:28
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may start with https://www.youtube.com/watch?v=Ku-fu_O9WmM
"ANSYS Fluent: Dynamic Mesh Problem for a Piston and Reed Valve - Part I"
ANSYS Fluent: Dynamic Mesh Problem for a Piston and Reed Valve - Part II
Setting Up a Dynamic Mesh Problem in Fluent For a Piston and Reed Valve Parts I
Setting Up a Dynamic Mesh Problem in Fluent For a Piston and Reed Valve Parts II
ndtrong likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 6, 2020, 20:25
Nguyen Duy Trong
Thank you Alexander for your recommendation.
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
