August 19, 2019, 06:48 |
UDF coding for dynamic mesh geometry lifting
Jiwon Yoon
Rep Power: 7 |
Hello UDF experts!
I'm trying to make a up and down movement(Y-axis movement) of 0.8mm with my geometry model. upward movement should take place with velocity of 0.65m/s during time 0~0.0014 sec. downward movement should take place with velocity of 0.43m/s during 0.0014~0.0033 sec. down below is my UDF but it does not compile properly #include "udf.h" #include "dynamesh_tools.h" DEFINE_CG_MOTION(nozzle, dt, cg_vel, cg_omega, time, dtime) { /* reset velocities */ NV_S (cg_vel, =, 0.0); NV_S (cg_omega, =, 0.0); /* compute velocity formula */ if (time <= 0.0014) { cg_vel[1] = 0.65; } else if (0.0014 < time < 0.0033) { cg_vel[1] = -0.43; } else { NV_S (cg_vel, =, 0.0); NV_S (cg_omega, =, 0.0); } message("\n"); message("\n y_velocity = %g \n",cg_vel[1]); } I also attatched my geometry file.(Trying to move all my geometry parts) any corrections to UDF or suggestions would be VERY helpful |
August 20, 2019, 01:35 |
Alexander
Rep Power: 34 |
message has capital M
Message0("\n"); Message0("\n y_velocity = %g \n",cg_vel[1]); |
August 20, 2019, 02:12 |
Jiwon Yoon
Rep Power: 7 |
Many Thanks to you..!
I have solved my UDF problem at last |
cg motion, dynamic mesh, udf |
UDF coding for dynamic mesh Needle valve lifting | Jiwon Y | Fluent UDF and Scheme Programming | 2 | August 19, 2019 06:20 |
how to simulate a velocity profile UDF with sliding mesh? | mani1455 | Fluent UDF and Scheme Programming | 0 | May 1, 2014 03:28 |
[ANSYS Meshing] Meshing Strategy for inside geometry | powpow | ANSYS Meshing & Geometry | 6 | January 16, 2013 05:32 |
Inner geometry gets lost exporting mesh from ICEM CFD to CFX-Pre | powpow | CFX | 3 | December 20, 2012 10:14 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 11:09 |
