July 4, 2019, 10:40 |
Running compiled UDFs on cluster
zobekenobe
Rep Power: 17 |
I am trying to run my simulation with a precompiled user defined function on a cluster, when ANSYS searches for the compiled UDF library which I have placed in the same folder it's unable to find it. The error I keep getting is Code:
Auto-compilation skipped. Could not find "libudf_3_MultiFLUX" or input files for creating "libudf_3_MultiFLUX" library I have also followed these steps https://www.sharcnet.ca/Software/Ans...x1-5800006.3.1 Any helps please!!1 |
July 6, 2019, 07:48 |
Svetlana Tkachenko
Rep Power: 15 |
Did you place your .cas and .c files into the same directory, and is it the same directory where you are starting fluent from?
July 7, 2019, 17:51 |
Rep Power: 27 |
You link to the manual of Fluent version 15. That is now five years old. Do you use this version on your cluster?
[Other] blueCFD-Core-2016 user compiled solvers not running in parallel | sbence | OpenFOAM Installation | 10 | December 5, 2018 09:44 |
[Other] Basic questions about OpenFOAM cluster running and installing | Fauster | OpenFOAM Installation | 0 | May 25, 2018 16:00 |
Openfoam running error in parallel in Cluster | sibo | OpenFOAM | 2 | February 25, 2017 14:26 |
Warning/Error message when running OF21 in cluster ROCKS | aerospain | OpenFOAM Running, Solving & CFD | 0 | May 10, 2012 07:12 |
Running FineTurbo on a Linux Cluster | Philipp Höfliger | Fidelity CFD | 3 | May 6, 2004 09:47 |
