Error with Velocity Profile UFD
Like Tree1Likes
  • 1 Post By pakk
Old   July 2, 2019, 04:15
Default Error with Velocity Profile UFD
Will
will.jones1995 is on a distinguished road
Hello everyone,
I'm hoping someone will be able to help me with an error on my UFD. I should start by saying that I have no knowledge of C, so a coding error was going to happen.
The Problem
I have the geometry shown in the image below, I want an fully developed velocity profile at the inlet with an x component.
The velocity components for the flow profile are shown below:
u/ui = 2(1-r^2), v/ui = 0 and w/ui = 0
My Code
As I said previously, I've no knowledge of C and there's an error in here somewhere. I've tried a couple of different things (including Googling), but I just can't seem to get it to work, so any help would be massively appreciated.
#include "udf.r"
DEFINE_PROFILE(inlet_x_velocity, thread, position)
	real x[ND_ND];    /* this will hold the position vector */
	real y;
	face_t f;
	r = 0.0127; /* radius in m */
	begin_f_loop(f,t)
	F_CENTROID(x,f,t);
	y = x[1];
	F_PROFILE(f,t,i) = 2 * (1 - (r * r))
	end_f_loop(f,t)
If anyone knows how to fix this to get it to work, I will be very grateful.
Thanking you all in advance,
Will
will.jones1995 is offline   Reply With Quote
Old   July 2, 2019, 08:01
pakk will become famous soon enough
If you try to compile this code, it does not work. You get errors. What you should do: read those errors!
The first error that I get:
..\..\src\temp.c(1): fatal error C1083: Cannot open include file: 'udf.r': No such file or directory
So, the compiler complains that it can not find the file "udf.r". Why does it look for that file? Because you told it to. You made a typo: it should be "udf.h", as it is in all examples in the Fluent manual.
OK, so I fixed that, and compiled again. Again errors:
..\..\src\temp.c(9): error C2065: 'r': undeclared identifier ..\..\src\temp.c(11): error C2065: 't': undeclared identifier
..\..\src\temp.c(11): error C2223: left of '->nelements_in_layer' must point to struct/union
..\..\src\temp.c(13): error C2065: 't': undeclared identifier
..\..\src\temp.c(13): error C2223: left of '->storage' must point to struct/union
..\..\src\temp.c(15): error C2065: 't': undeclared identifier
..\..\src\temp.c(15): error C2223: left of '->storage' must point to struct/union
..\..\src\temp.c(15): error C2065: 'i': undeclared identifier
..\..\src\temp.c(15): error C2065: 'r': undeclared identifier
..\..\src\temp.c(16): error C2143: syntax error: missing ';' before '}'
Always start on the top. The first error is that 'r' is undeclared. So the solution: declare it! Tell the compiler what 'r' is. You want it to be a variable that is a floating number. Similarly, you use 't' and 'i', but you never told the compiler what they are. I don't know where you started from, but actually 't' should be the same as 'thread' in the declaration, and 'i' should be the same as 'position' in the declaration.
After fixing that, I compile again, and see one error remaining:
Aha, you forgot to put a semicolon after your statement.
I added the semicolon, and the compilation went perfect.
So to conclude: compile, and look at the errors. You might not understand the error, but if you don't try you'll never know.
will.jones1995 likes this.
pakk is offline   Reply With Quote
Old   July 3, 2019, 19:37
Will
Thanks pakk, that was really helpful.
Plot velocity profile along longitudinal axis of pipe jorgelmilan EnSight 8 July 7, 2018 15:30
[UDF] Relative coordinates in logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 25 July 13, 2017 04:44
InterFoam - Validation for velocity profile in simple channel me.ouda OpenFOAM Running, Solving & CFD 0 October 19, 2015 07:42
Logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 0 April 23, 2009 20:09
[boundary condition] logarithmic velocity profile cfdworker FLUENT 2 April 18, 2009 00:36
