May 21, 2019, 11:00 |
Time varying porosity/viscous resistance
Anonymous
Dear all,
I am working on a project in which I would like to vary the porosity or viscous resistance in a domain over time. This is the UDF I tried to interpreted in Fluent: #include "udf.h" //file that contains definitions for define functions and fluent operations DEFINE_PROFILE(vis_res,th,i) { real x[ND_ND]; real a; real t = CURRENT_TIME; cell_t c; begin_c_loop(c,th) { C_CENTROID(x,c,th); if(t >= 0 && t <= 0.4) a = 1e9; else(t > 0.4 && t <= 0.8) a = 1.0; F_PROFILE(c,th,i) = a; } end_c_loop(c,th) } I received errors, I hope someone can help me to modify the UDF. Thanks in advance!! |
May 22, 2019, 06:43 |
Alexander
Rep Power: 34 |
what kind of error did you get? describe in details, put here console output
best regards |
May 27, 2019, 06:36 |
Rep Power: 27 |
Your "else" should be "else if".
November 4, 2019, 13:20 |
Time dependant viscous resistance
shivam salokhe
Rep Power: 9 |
Hello, I am working on the same problem but in my case, I need to modify the visc resistance using an equation which is the function of wetting time of cell and total flow time. To do so, I am using the VOF approach to model the two-phase flow in porous media. So the following things I expect from UDF
1. Consider for a cell, it should record the time when the volume fraction becomes unity (tw) which varies for different cells. 2. The viscous resistance for secondary phase should be modified using the following equation a = (1/(3.7E-15*(current_time-tw)^2-1.75E-12*(current_time-tw)+6E-10)) any suggestions on this? |
November 4, 2019, 14:32 |
Rep Power: 27 |
I guess the challenge is in the first part. In pseudo-code:
Add one UDM, which will represent the wetting time per cell. Initialize this UDM at a large value. Add a scalar update: For each cell: Check if the vof is 1 If so, check if the current time is below the UDM value. If so, update the UDM value to the current time. |
November 5, 2019, 07:21 |
shivam salokhe
Rep Power: 9 |
#include "udf.h"
DEFINE_PROFILE(vis_res,c,i) { int phase_domain_index; cell_t cell; Thread *cell_thread; Domain *subdomain; real xc[ND_ND]; real current_time; current_time = CURRENT_TIME; sub_domain_loop(subdomain, mixture_domain, phase_domain_index) /* loop over all subdomains (phases) in the superdomain (mixture) */ { if (DOMAIN_ID(subdomain) == 2) /* loop if secondary phase */ thread_loop_c (cell_thread,subdomain) /* loop over all cell threads in the secondary phase domain */ { begin_c_loop_all (cell,cell_thread) /* loop over all cells in secondary phase cell threads */ { C_CENTROID(xc,cell,cell_thread); if C_VOF(cell,cell_thread) = 1.; /* if volume fraction to 1*/ tw = C_time(c,t); /*wetting time*/ C_UDMI(c,t,0)=tw; /*saving wetting time*/ a = (1/(3.7E-15*(current_time-tw)^2-1.75E-12*(current_time-tw)+6E-10)); else a =(1/9E-10); F_PROFILE(c,t,i) = a; } } } end_c_loop_all (cell,cell_thread) From ansys udf manual I have created this UDF. Since I am new to this. I would like to have your comments and suggestions on the same. |
November 5, 2019, 08:47 |
Rep Power: 27 |
After some grammar fixes:
#include "udf.h" DEFINE_PROFILE(vis_res,t,i) { int phase_domain_index; cell_t cell; Thread *cell_thread; Domain *subdomain; real a; real current_time = CURRENT_TIME; sub_domain_loop(subdomain, mixture_domain, phase_domain_index) /* loop over all subdomains (phases) in the superdomain (mixture) */ { if (DOMAIN_ID(subdomain) == 2) /* loop if secondary phase */ thread_loop_c (cell_thread,subdomain) /* loop over all cell threads in the secondary phase domain */ { begin_c_loop_all (cell,cell_thread) /* loop over all cells in secondary phase cell threads */ { if (C_VOF(cell,cell_thread) > 0.99999) /* if volume fraction is close enough to one*/ { if (C_UDMI(cell,t,0)==0) C_UDMI(cell,t,0)=current_time; /*saving wetting time only if it is the first time that it wets*/ a = (1/(3.7E-15*pow(current_time-C_UDMI(cell,t,0),2)-1.75E-12*(current_time-C_UDMI(cell,t,0))+6E-10)); } else { a = (1/9E-10); } F_PROFILE(cell,t,i) = a; } } } end_c_loop_all (cell,cell_thread) } And I think it can be simplified a lot further, but I am not so experienced with writing for secondary phases, and I don't have Fluent right now: Code:
#include "udf.h" DEFINE_PROFILE(vis_res,t,i) { cell_t cell; real current_time = CURRENT_TIME; begin_c_loop_all (cell,t) /* loop over all cells in secondary phase cell threads */ { if (C_VOF(cell,t) > 0.99999) /* if volume fraction is close enough to one*/ { if (C_UDMI(cell,t,0)==0) C_UDMI(cell,t,0)=current_time; /*saving wetting time only if it is the first time that it wets*/ F_PROFILE(cell,t,i) = (1/(3.7E-15*pow(current_time-C_UDMI(cell,t,0),2)-1.75E-12*(current_time-C_UDMI(cell,t,0))+6E-10)); } else { F_PROFILE(cell,t,i) = (1/9E-10); } } end_c_loop_all (cell,t) } |
November 5, 2019, 08:54 |
shivam salokhe
Rep Power: 9 |
Thanks a lot for simplifications. I look forward to testing it
porosity, viscous resistance |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 42 | May 8, 2024 00:17 |
Elastic or Plastic Deformations in OpenFOAM | NickolasPl | OpenFOAM Pre-Processing | 36 | September 23, 2023 09:22 |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 03:36 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 14:40 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 08:56 |
