total heat
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   May 3, 2019, 08:23
Default total heat
anonymous
cfd new is on a distinguished road
i am giving heat variation with respect to axis of the domain, inside the domain through udf. And now i want to check that software is taking correct profile and total heat inside the domain. I am giving this heat using DEFINE_SOURCE macro.
Where can i see the total heat dumped in the domain?
at the same time how can i plot the variation of heat with respect to axis (as given by udf) ?
Thanks in advance.
cfd new is offline   Reply With Quote
Old   May 6, 2019, 23:52
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may use user-defined variables (UDMIs) to see your source
good examples you may find in ansys fluent customization manual
best regards
cfd new likes this.
AlexanderZ is offline   Reply With Quote
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 1 April 14, 2020 04:27
Heat Release vs. Apparent Heat Release // Comparison with GT Power MFGT CONVERGE 10 August 17, 2016 03:38
Problem with total heat transfer rate aswathy_raghu FLUENT 0 July 26, 2016 08:39
total pressure influence on heat transfer fab Main CFD Forum 8 May 19, 2005 10:24
Help! Total heat transfer rate doesn´t sum to zero Thomas FLUENT 0 April 6, 2005 03:55
