UDF macros
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   March 18, 2019, 10:33
Default UDF macros
imane
zahrae is on a distinguished road
In my case study, I have to creat some udfs wich uses the radial velocity of the fluid and the radial gradient of velocity. I don’t know how to set these two parameters using fluent macros !
Please help !!
zahrae is offline   Reply With Quote
Old   March 18, 2019, 22:00
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
all depends on your case.
macros for velocities and gradients of velocities:
C_U(c,t)
C_V(c,t)
C_W(c,t)
G_C_U(c,t)
G_C_V(c,t)
G_C_W(c,t)
convert to cylindrical coordinates to get radial values
best regards
AlexanderZ is offline   Reply With Quote
Old   March 19, 2019, 06:55
imane
Thanks you for your reply!
I am modeling deposition of particles by DPM in a surface of a tube and I have to code the forces responsible for this deposition, drag force depends on the radial velocity and the lift force depends on the radial gradient of velocity.
My geometry is a 3d tube inside of it the fluid flows in the Z direction.
I have created those macros for radial gradient and radial velocity:
du/dr=C_U_G(c,t)[0]
ur=C_U(c,t)[0]
0 means the x direction (I suppose the x direction is the radial direction) but I am not sure. should I use the cylindrical coordinates and how ?Can you please if possible give me some guidelines !
Old   March 19, 2019, 22:17
Alexander
du/dr=C_U_G(c,t)[0]
ur=C_U(c,t)[0]
are wrong, read description of these macros,
cylindrical coordinates is your homework
best regards
zahrae likes this.
Old   April 2, 2019, 09:45
imane
helloo!
Now I know how to express the velocities in cylindrical coordinates the difficulty lies in expressing their gradient.
The macro used for expressing the gradient in fluent is: C_U_G (c,t) [i] i=0, 1,2 for x, y, z positions respectively.
But for the cylindrical coordinates I don’t know how to express radial, tangential and axial positions.
please help I m stuck with this problem, I have to resolve this problem very queckly!!
Old   April 2, 2019, 22:00
Alexander
google -> "cartesian coordinates to cylindrical coordinates"
first link: http://www.math.tamu.edu/~glahodny/M...ion%2013.9.pdf
best regards
Old   April 4, 2019, 19:29
imane
Thanks for your response!
But this isn't what I am searching for, By the program shown below I can found the radial,tangential and axial velocities and also the unit vectors in cylindrical coordiantes.
Now I should code the gradient of the radial velocity. the gradient of a function f in cylindrical coordiantes is writing as:
∆f=∂f/∂r e_r+1/r + ∂f/∂θ e_θ+∂f/∂z e_z
so the difficulty is how to write macros of these terms, specialy for the derivation in the radial and tangential directions (∂f/∂r e_r+1/r + ∂f/∂θ e_θ). I don't know how to deal with this. Any guidelines please!
real NV_VEC(origin), NV_VEC(axis);
real NV_VEC(V), NV_VEC(r), NV_VEC(R), NV_VEC(B);
real NV_VEC(er), NV_VEC(et);
real xc[ND_ND];
real Bmag, rmag, source;
real ua, ur, ut;
/* Get origin vector of fluid region */
NV_V (origin, =, THREAD_VAR(thread).cell.origin);
/* Get axis of fluid region */
NV_V (axis, =, THREAD_VAR(thread).cell.axis);
/* Store the 3 cartesian velocity components in vector V */
N3V_D(V, =, C_U(cell,thread),C_V(cell,thread),C_W(cell,thread) );
/* Get current cell coordinate */
C_CENTROID(xc,cell,thread);
/* Calculate (R) = (Xc)-(Origin) */
NV_VV(R, =, xc, -, origin);
/* Calculate |B| = (R) dot (axis)*/
Bmag = NV_DOT(R,axis);
/* Calculate (B) = |B|*axis */
NV_VS(B,=,axis,*,Bmag);
/* Calculate (r) = (R)-(B) This is the local radial vector*/
NV_VV(r, =, R, -, B);
/* Calculate |r|*/
rmag = NV_MAG(r);
if (rmag != 0.)
NV_VS (er,=,r,/,rmag);
NV_CROSS(et, axis, er);
ur = NV_DOT(V,er);
ut = NV_DOT(V,et);
ua = NV_DOT(V,axis);
else
ur = 0.0;
ut = 0.0;
Old   April 9, 2019, 07:30
imane
No one has the answer of my question!!
I really need help. I read all the manuel of the UDF's but I didn't find anything, any guidelines please !!
Thank you for your kind cooperation!
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
Grid Macros for UDF elena FLUENT 0 May 9, 2006 09:44
UDF Macros tom FLUENT 1 April 26, 2006 06:40
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
