Interpret UDF in linux systems - Error
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   February 20, 2019, 07:42
Default Interpret UDF in linux systems - Error
WhiteW is on a distinguished road
I'm using an UDF in my analysis, the code works properly in a Windows system, the UDF is interpreted and I can use it inside my analysis.
/define/user-defined/interpreted-functions
"userdefined_6.c"
"cpp"
10000
no
However, when I try to do the same in a Linux environment, the UDF is not interpreted. I get this error:
Error: "userdefined_6.c": line 1: syntax error.
sh: /mypc/prod/applications/ansys/171/binary/v171/fluent/contrib/lnamd64/cpp: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
The line 1 contains:
#include "udf.h"
What could the problem be?
Thanks,
WhiteW
WhiteW is offline   Reply With Quote
Old   February 22, 2019, 06:47
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
I have no experience with Linux
from google i found that most likely your problem is in compiler: conflict in x32 and x64 versions
try
yum install glibc.i686
or
yum install glibc.i386
I recommend you to compile your UDF not interpritate
best regards
WhiteW likes this.
AlexanderZ is offline   Reply With Quote
Old   February 25, 2019, 11:51
Thanks AlexanderZ!
Old   September 11, 2020, 00:33
Default error of interpreting udf on a linux system
Haocheng Yu
HaochengYu is on a distinguished road
Hi, WhiteW!
Recently, I encountered the same problem with you about interpreting udf on linux system. The udf also runs well on windows using the command like you. Unfortunately, when i do the same in a Linux environment, the same error occurs:
sh: /opt/software/ansys_inc/v190/fluent/contrib/lnamd64/cpp: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
Error: "plate.c": line 1: syntax error.
The first line of my udf code is " #include "udf.h"".
Could you please teach me how you handled the problem?
Thanks in advance.
Yours,
HC Yu
HaochengYu is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
