UDF compiling problem
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   January 15, 2019, 17:40
Default UDF compiling problem
elia_l is on a distinguished road
Hi guys,
I had this problem with compiling following UDF coming from a famous tutorial coming from CFDninja (about dynamic mesh technics). Could anyone help me with understanding the motivation of this problem?
I ran fluent as standalone mode (out of workbench), 2d mode, double precision and SERIAL as per tutorial instructions.
Check images attached.
Thanks in advance,
ELia
elia_l is offline   Reply With Quote
Old   January 15, 2019, 21:32
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you should recompile UDF using your fluent version.
What version are you using? If it is higher than 19.0, than fluent is running on parallel regime by default (you put single core, but still it will be parallel with 1 host node and 1 computational node)
best regards
elia_l likes this.
AlexanderZ is offline   Reply With Quote
Old   January 16, 2019, 13:04
Hi Alexander,
I probably fixed the problem. I installed visual studio and now it works.. About mpi, you are right, even I selected serial, when fluent starts, it displays it changes to parallel. Probably it needed some stuff to get compiled the libudf... I still don't know what, cause I'm a beginner, but I'll get in deep with this as soon as possible.
Thanks a lot for the fast reply.
Bye,
Elia
Problem loading UDF in Linux environment hjan23 FLUENT 0 December 15, 2017 05:09
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. Ari Fluent UDF and Scheme Programming 4 May 31, 2016 09:51
Problem with compiling UDF in Fluent amojodi Fluent UDF and Scheme Programming 4 April 14, 2015 10:01
HELP! Problem compiling UDF function Syrakus FLUENT 6 April 7, 2006 11:48
UDF compiling problem for 3D simulation Marijo FLUENT 1 March 28, 2006 04:21
