Body_Force_UDF Trouble
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   December 20, 2018, 17:59
Red face Body_Force_UDF Trouble
RCamp is on a distinguished road
Hi everyone,
I am working on a body force UDF right now and am having some trouble. I am pretty new to programming so it may be something very simple but I keep getting an error that says
"Contact_force_body_force.c(13): error C2109: subscript requires array or pointer type
Contact_force_body_force.c(18): error C2109: subscript requires array or pointer type"
I am a little confused by this because I thought the tp was the pointer and that the i should be Cartesian coordinates already build in. Can someone help out?
My code is:
#include "udf.h"
#define TSTART 5.0 /* field applied at t = tstart */
DEFINE_DPM_BODY_FORCE(particle_body_force,tp,i)
{ real bforce=0;
real deltaV=0;
if(TP_TIME(tp)>=TSTART)
if(i==0)
deltaV= TP_VEL(tp)[0]-TP_VELO(tp)[0];
bforce=TP_Mass(tp)*deltaV;
else if(i==1)
deltaV= TP_VEL(tp)[1]-TP_VELO(tp)[1];
else
deltaV=0;
bforce=0;
RCamp is offline   Reply With Quote
Old   December 21, 2018, 01:07
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
change
real deltaV=0;
to
real deltaV[3];
velocity is a vector not scalar
best regards
RCamp likes this.
AlexanderZ is offline   Reply With Quote
Old   December 28, 2018, 11:28
The ultimate answer to this for anyone with a similar problem was to take out deltaV and just use that equation directly in my bforce.
After that the only issue was I was using a O instead of a zero.
19.1, body_force, fluent - udf
[waves2Foam] Having a lot of trouble for a short wavelengths arieljeds OpenFOAM Community Contributions 1 January 2, 2024 14:10
Trouble with rotating wall boundary condition king1989 OpenFOAM Running, Solving & CFD 7 July 29, 2016 14:44
Trouble with sampleDict syntax for OpenFOAM 2.3.1 rawdoggity OpenFOAM Post-Processing 1 February 1, 2015 06:24
[ICEM] trouble with mesh quality from ICEM in CFX Solver escher25 ANSYS Meshing & Geometry 0 February 28, 2011 08:38
[GAMBIT] Trouble meshing complex VOF geometry RPJones ANSYS Meshing & Geometry 2 February 14, 2011 19:54
