How to write a udf for temp dependent emissivity |
December 9, 2018, 12:26 |
Oula
Rep Power: 11 |
Hi everyone
In my model there are some boundaries (walls) that their emissivities change with temperature. For example at a specific wall at T=200 C emissivity = 0.80 T=400 C emissivity = 0.82 T=600 C emissivity = 0.84 How can I write the suitable UDF for this case? Any help is much appreciated |
December 10, 2018, 11:00 |
Oula
Rep Power: 11 |
I'm a bit confused about which macro can be used to change the material property that is changing with temperature?, is it DEFINE PROPERTY or DEFINE PROFILE?
I have found the thread below which used DEFINE PROFILE. can anybody explain to me what is the difference. Temp dependent emissivity udf Any help is much appreciated |
December 10, 2018, 21:10 |
Alexander
Rep Power: 34 |
DEFINE PROPERTY macro is used to define material properties
DEFINE PROFILE is used to define a custom boundary profile or cell zone condition emissivity is not material property, but property of surface, so you should use DEFINE PROFILE best regards |
Temp dependent emissivity udf | rossyd89 | Fluent UDF and Scheme Programming | 4 | December 10, 2018 10:50 |
confusion on how to write udf for density of a mixture solution in multiphase problem | Hirakjyoti | Fluent UDF and Scheme Programming | 1 | September 11, 2017 02:21 |
How to write UDF to achieve phase chang | dunga82 | Fluent UDF and Scheme Programming | 2 | May 8, 2013 23:16 |
How to write UDF to achieve phase chang | dunga82 | Fluent UDF and Scheme Programming | 0 | May 6, 2013 09:50 |
UDF to write interp files | Karl | FLUENT | 6 | February 7, 2002 13:10 |
