Time dependent sinus velocity inlet UDF
Like Tree1Likes
  • 1 Post By obscureed
Old   December 6, 2018, 14:07
Question Time dependent sinus velocity inlet UDF
LinW is on a distinguished road
Hey,
I've spent a few hours trying to set up a UDF for a 2D velocity inlet.
Nothing special but as im relatively new to fluent and completely new to C im facing some errors.
I wan't to do a transient simulation of water flow where the u (x-velocity) inlet profile is a time and space dependent sinus.
The formula it should solve looks like this: u(y,t)=2*sin(5*t+0.1*y). Im not sure whether the following code is suitable to solve this equation for every node (centroid?) and adds a node-specific phase angle phi(y) where y is the number of the node. (Position in the Array)
I shloud propably mention, that the specific u-profile is supposed to only be "active" in a specified time.
Starting with zero C knowledge a few hours ago, but with the help of this forum and the manual, i've put together the following code.
I hope there arent too many mistakes left. I tried to let fluent interpret the UDF but it keeps failing at line 25 saying: parse error.
The encoding can't be the cause as i chose ANSI.
P.S.: Is there a way to read out the amount of entrys in the x[ND_ND] array?
Thanks a lot already.
My UDF:
#include "udf.h"
#define PI 3.141592654
#define N 600 //Amount of nodes
#define Y_max 0.3 //Max. amplitude
#define U_inf 1.2 //Base velocity
#define W 0.502654825 //Angular velocity
DEFINE_PROFILE(inlet_u_velocity,thread,position)
float x[ND_ND];
float y; //?
face_t f;
double t = CURRENT_TIME; //Time
begin_f_loop(f,thread) //here the "parse-error" occurs
F_CENTROID(x, f, thread);
y=x[1]; //gives y-coordinate
if(t >= 0 && t <= 1) //Base velocity at beginning
F_PROFILE(f,thread,position) = 1,2);
if(t > 1 && t <= 13.5) //Varying velocity
F_PROFILE(f,thread,position) = Y_max*sin(W*t+(2*PI*y/N)); //For every timestep this equation has to be solved for every centroid y
else if(t > 13.5) //Base velocity for the rest of the time
F_PROFILE(f,thread,position) = 1,2;
end_f_loop(f,thread)
LinW is offline   Reply With Quote
Old   December 6, 2018, 20:34
obscureed is on a distinguished road
Hi LinW
Are you sure you're counting lines correctly? Because one line that looks bad to me is
which could easily be line 25. Lines are counted from the top of the text file. Line 31 is also bad. You cannot supply a vector here -- you can only supply one component.
Your "if" statements hang together fairly well, but the neatest structure (without repeating values, for example) is
if(t < 1.0) {
} else if (t < 13.5) {
} else {
I would always recommend compiling UDFs rather than interpreting. M_PI is built-in and needs no definition; if you run in double precision, it will be more accurate than your value (not that this matters much).
Good luck!
Ed
LinW likes this.
obscureed is offline   Reply With Quote
Old   December 7, 2018, 12:22
Thanks a lot!
You're right... i added the comment in the wrong line.
The Solution for the Problem was the brace in line 25 and the commas in Line 25 and 31. Additionally i changed the y in Line 25 against x[1] and deleted Line 11.
Now it seems to work.
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
UDF problem- time dependent temperature at inlet kaeran FLUENT 1 June 16, 2015 22:48
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
can i set the velocity and pressure at the inlet at the same time by UDF minyang.cau FLUENT 0 July 15, 2009 00:14
