Inlet temperature as a function of outlet temperature UDF |
November 5, 2018, 09:44 |
William Harvey
Rep Power: 8 |
I am currently working on a project where cooling towers need to be simulated. The cooling towers work the following way: -A constant flow of air enters the side of the tower at a certain temperature -The same flow of air exits the top of the tower at a higher temperature I'd like to use a UDF to impose a relationship between the temperature parameters (ex: T_outlet = avg(T_inlet)+30). I have UDFs where the temperature varies in time, but none where the temperature varies with respect to some other temperature in the domain. Does anybody know how I could achieve this? Thanks in advance. |
November 23, 2021, 12:05 |
Rep Power: 5 |
It's a shame this didn't get a reply.
I'm having similar issues as I need to define an outlet temperature to equal the temperature of the fluid body immediately prior to the outlet. My simulation uses an oscillating fluid flow so defining a constant outlet temperature affects my simulation greatly. My C knowledge is minimal; I can write the basic programs to compute "hello world", convert Celsius to Fahrenheit and determine whether a number is prime or not; but composing some C-code for a UDF is a different kettle of fish entirely. #include "udf.h" DEFINE_PROPERTY(outlet_temperature) { Domain *d; real tavg =0.; real temp, volume, vol_tot; Thread *t; face_t f; d = Get_Domain(1) begin_f_loop(c,t) { volume = C_VOLUME(f,t); /* face volumes */ temp = F_T(f,t); /* face temperatures */ vol_tot += volume; tavg += temp*volume; } end_f_loop(c,t) tavg /=vol_tot } This is something that I have butchered from the UDF manual. I don't think it is even close to being correct. What I want the code to do is define the outlet temperature as equal to the temperature immediately prior to the outlet. If this is how "faces" work, then what I'd want is to define the temperature of the final face as equal to the temperature of the preceding face. I am using a laminar solver and a transient fluid flow with a defined inlet temperature, with an oscillating fluid velocity. Any help would be greatly appreciated. |
November 24, 2021, 03:44 |
Alexander
Rep Power: 34 |
#include "udf.h" DEFINE_PROFILE(outlet_temperature,t,i) { face_t f; real temperature; begin_f_loop(f,t) { c0 = F_C0(f,t); /*get pointer to cell adjusted to face*/ t0 = THREAD_T0(t); /*get pointer to thred adjusted to face*/ temperature = C_T(c0,t0); /*get temperature in cell adjusted to face*/ F_PROFILE(f,t,i) = temperature; /*apply temperature from cell adjusted to face to that face*/ } end_f_loop(f,t) }
best regards ****************************** press LIKE if this message was helpful |
November 24, 2021, 12:54 |
Rep Power: 5 |
Hi AlexanderZ. Many thanks for your sample code, with very helpful code comments.
Apologies for the follow-up questions; Did you define t0 and c0 as real? When I try to interpret the function using ansys I get the following two errors: invalid type conversion: pointer to structure -> double (for t0 = THREAD_TO(t); ) invalid type conversion: double -> pointer to char (for temperature = C_T(c0,t0); ) I am also running this simulation with parallel processing, will this be an issue? Thank you James |
November 24, 2021, 22:21 |
Alexander
Rep Power: 34 |
I forgot to define c0,t0
compile code Code:
#include "udf.h" DEFINE_PROFILE(outlet_temperature,t,i) { face_t f; cell_t c0; thread *t0; real temperature; begin_f_loop(f,t) { c0 = F_C0(f,t); /*get pointer to cell adjusted to face*/ t0 = THREAD_T0(t); /*get pointer to thred adjusted to face*/ temperature = C_T(c0,t0); /*get temperature in cell adjusted to face*/ F_PROFILE(f,t,i) = temperature; /*apply temperature from cell adjusted to face to that face*/ } end_f_loop(f,t) }
November 25, 2021, 07:06 |
Rep Power: 5 |
Works perfectly, thank you!
fluent - udf, fluent 14.5, temperature bc, temperature calculation |
Reversed flow using pressure inlet and outlet? | here_for_help | FLUENT | 0 | September 28, 2018 16:20 |
Inlet temperature = outlet temperature + offset? | GerHan | OpenFOAM Pre-Processing | 5 | November 14, 2016 07:36 |
UDF profile: Fluent method for coupling inlet and outlet | I-mech | Fluent UDF and Scheme Programming | 0 | May 10, 2014 11:36 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 01:35 |
