warning C4700: uninitialized local variable 'tmin' used?
Like Tree1Likes
  • 1 Post By obscureed
Old   October 29, 2018, 10:35
Default warning C4700: uninitialized local variable 'tmin' used?
Oula
Oula is on a distinguished road
Hi everyone
I'm getting the following warning when I compil a UDF function in fluent.
Does anyone have any idea why?. Please see below the function. Any help is much appreciated
#include "udf.h"
#define ID 8
DEFINE_EXECUTE_AT_END(wall_temp)
#if !RP_HOST
face_t f;
real temp, tmax, tmin;
real value;
Domain *domain = Get_Domain(ROOT_DOMAIN_ID);
Thread *t = Lookup_Thread(domain,ID);
begin_f_loop(f,thread)
temp = F_T(f,t);
value = (temp - tmin) / (tmax-tmin);
F_UDMI(f,t,0) = value;
F_UDMI(F_C0(f, t), t->t0, 0) = value;
end_f_loop(f,thread);
#endif
Oula is offline   Reply With Quote
Old   October 29, 2018, 10:47
obscureed is on a distinguished road
Hi Oula,
That error message can be restated: you use the value of "tmin" in a calculation, but you have not put a value into "tmin". This is true in your code, and it is a serious problem -- the compiler calls it a warning (rather than an error), but it means that all your calculations could be garbage. You need to give "tmin" a value (for example "tmin = 100.0;") before you use it.
Also, in "begin_f_loop(f,thread)" and "end_f_loop(f,thread);", there is no variable called "thread" -- you should use "t" instead. Also, strictly speaking, that semicolon is unnecessary.
Good luck!
Ed
Oula likes this.
obscureed is offline   Reply With Quote
Caffa 3D code Waliur Rahman Main CFD Forum 0 May 29, 2018 01:53
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
