Controlling the UDF within the Minute
Like Tree2Likes
  • 1 Post By blackmask
Old   October 20, 2018, 03:18
Default Controlling the UDF within the Minute
Siddharth
siddhu23 is on a distinguished road
Hi Folks,
I am siddhu.
I having a code for controlling the heatflux 5min the given value and next 5min will be zero.
#include "udf.h"
DEFINE_PROFILE(5min_ON_5min_OFF,thread,position)
  face_t f;
  int i,i_step;
  real time,heat_flux,t1_sec,t2_sec;
  i_step = 6;
  t1_sec=300;
  t2_sec=300;
  heat_flux = 12345;
  time=CURRENT_TIME;
  begin_f_loop(f,thread)
   for (i=0;i<=i_step;i++)
      if (time>=(i*(t1_sec+t2_sec)) && time < (i*(t1_sec+t2_sec)+t1_sec))
        F_PROFILE(f,thread,position)=heat_flux;
      if (time >= (i*(t1_sec+t2_sec)+t1_sec) && time < (i*(t1_sec+t2_sec)+t1_sec+t2_sec))
        F_PROFILE(f,thread,position)=0.0;
  end_f_loop(f,thread)
transient
Time step size : 60
Number of time step : 60
This code working.
Now I want write a UDF for turn the heatflux ON and OFF for 85 times for each one minute. I am will run this
transient
Time step size : 60
Can you anyone please write the UDF for this condition. Please refer the CODE I have given.
siddhu23 is offline   Reply With Quote
Old   October 21, 2018, 00:38
blackmask will become famous soon enough
FYR.
#include "udf.h"
DEFINE_PROFILE(five_min_ON_five_min_OFF,thread,position)
  face_t f;
  int i_repeat, n_repeats;
  real time, heat_flux, t1_sec, t2_sec, i_sec;
  real hf;
  t1_sec=300;
  t2_sec=300;
  n_repeats = 85;
  heat_flux = 12345;
  time=CURRENT_TIME;
   * time = i_repeat*(t1_sec + t2_sec) + i_sec;
   * where i_repeat is the largest integer s.t.
   * 0 < i_sec < t1_sec + t2_sec
   * The heat flux is then determined by comparing
   * i_sec and t1_sec.
  i_repeat = time/(t1_sec+t2_sec);
  if (n_repeats <= i_repeat) return;
  i_sec = time - i_repeat*(t1_sec+t2_sec);
  if (i_sec < t1_sec)
      hf = heat_flux;
  else
      hf = 0.0;
        F_PROFILE(f,thread,position) = hf;
siddhu23 likes this.
blackmask is offline   Reply With Quote
Old   October 22, 2018, 00:34
Siddharth
Originally Posted by blackmask View Post
FYR.
#include "udf.h"
  face_t f;
  real hf;
  t1_sec=300;
  t2_sec=300;
  n_repeats = 85;
  heat_flux = 12345;
  time=CURRENT_TIME;
   * i_sec and t1_sec.
  if (i_sec < t1_sec)
      hf = heat_flux;
  else
      hf = 0.0;
Thank you so much I will try this and let you know
Old   October 22, 2018, 06:11
Siddharth
1st
#include "udf.h"
  face_t f;
  int i,i_step;
  i_step = 6;
  t1_sec=300;
  t2_sec=300;
  heat_flux = 12345;
  time=CURRENT_TIME;
You can see the image for 1st one.
i want to write UDF for 2nd case. Please write a code for that(2nd case).
Each and every minute need to turn the fulx ON 85 time and 85 time OFF(170 times triggering in one minute).
Old   October 22, 2018, 06:24
You only need to adjust the time intervals and number of repeats.
#include "udf.h"
DEFINE_PROFILE(ON_OFF,thread,position)
  face_t f;
  real hf;
  t1_sec=1.0/170;
  t2_sec=1.0/170;
  n_repeats = 85*60;
  heat_flux = 12345;
  time=CURRENT_TIME;
   * i_sec and t1_sec.
  if (i_sec < t1_sec)
      hf = heat_flux;
  else
      hf = 0.0;
udf for one dimensional linear motion based on force maccheese Fluent UDF and Scheme Programming 2 September 1, 2019 03:18
Save output of udf in another udf! JuanJoMex FLUENT 0 February 8, 2018 13:43
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
