how to use DEFINE_GEOM to change the geometry with time?
Like Tree1Likes
  • 1 Post By blackmask
Old   September 13, 2018, 06:08
Thumbs down how to use DEFINE_GEOM to change the geometry with time?
dengdeng is on a distinguished road
I am simulating the flow around an object deforming with time. The time-dependent function of the boundary is already known(it has the form of y=f(x,t)).
I've got some basic infomation of DEFINE_GEOM on this page:
http:////www.sharcnet.ca/Software/An...fine_geom.html
However, it seems no argument related to time is included in this script. I tried to add the variable time like this:
DEFINE_GEOM(BL_FP1,domain,dt,position,time)
and the UDF failed to be compiled.
Has anyone worked on similar case before? Any help or suggestion is welcome.
Thank you.
dengdeng is offline   Reply With Quote
Old   September 13, 2018, 07:12
blackmask will become famous soon enough
You can use the following code.
DEFINE_GEOM (BL_FP1, d, dt, position)
real time = CURRENT_TIME;
dengdeng likes this.
blackmask is offline   Reply With Quote
Old   September 13, 2018, 10:06
It works! Thank you : )
define_geom, udf
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
Elastic or Plastic Deformations in OpenFOAM NickolasPl OpenFOAM Pre-Processing 36 September 23, 2023 09:22
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
