UDF should be written in C or C++ standard?
Like Tree3Likes
  • 2 Post By blackmask
  • 1 Post By pakk
Old   September 1, 2018, 15:36
Question UDF should be written in C or C++ standard?
Roh
Roh is on a distinguished road
Guys,
UDF should be written in C or C++ standard? in some places I've heared that it should be written in C and another places heared that should be written in C++? if C++, so can we use OOP?
Roh is offline   Reply With Quote
Old   September 2, 2018, 00:30
blackmask will become famous soon enough
It does not matter if you use compiled UDF. You can do a major part of your work using C/C++/FORTRAN as you please. However you need to wrap it with a C interface. You should stick to C if mixed language programming sounds foreign to you.
Roh and THA SEANGHAI like this.
blackmask is offline   Reply With Quote
Old   September 3, 2018, 05:41
pakk will become famous soon enough
The simple answer: C.
Everything in the manual is written in C. All examples that you will encounter: C.
Now, it is possible to set C up such that it accepts functions from Fortran or C++. For 99.999% of all cases, this is needlessly complicated, and should not be done. Just do it in C.
Roh likes this.
pakk is offline   Reply With Quote
Old   September 10, 2018, 02:26
gearboy is on a distinguished road
Originally Posted by Roh View Post
Guys,
See the UDF debugging tool using VC++.
It writes udf in C++ language, so OOP is of course allowed.
https://vcudfstudio.bitbucket.io/
gearboy is offline   Reply With Quote
Old   December 30, 2020, 08:13
elochana is on a distinguished road
Ansys Fluent UDF manual 2019 R2 says
"A user-defined function, or UDF, is a C or C++ function that can be dynamically loaded with the ANSYS Fluent solver to enhance its standard features. For example, you can use a UDF to:..."
elochana is offline   Reply With Quote
Old   December 30, 2020, 09:14
Interesting find.
As far as I am aware, Fluent compiles with the c-compiler. C and C++ are not the same, but share syntax, so many C++ functions are also valid C. But not all.
So, unless there is an option that I am not aware of to change the compiler, this is just marketing. They can claim to support a popular language, and they are misleading, but just enough correct to defend it.
My advice remains: use C.
(Exception for experienced C++ programmers, but they wouldn't ask this question.)
Old   December 31, 2020, 09:09
I will try a simple C++ udf both as interpreted and compiled and see..
Old   December 31, 2020, 11:36
Nice idea, can you share the results? (and the simple C++ udf?)
Want help regarding the UDF that is been written in VS code related to weber number saratunni07 CFD Freelancers 0 May 20, 2017 03:30
Help with unsteady calculation with source/sink UDF RobV FLUENT 1 November 13, 2016 06:44
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 07:12
