What compilers can we use in Ansys Fluent to compile our UDF?
Like Tree6Likes
  • 2 Post By blackmask
  • 1 Post By pakk
  • 1 Post By gearboy
  • 1 Post By gearboy
  • 1 Post By gearboy
Old   September 1, 2018, 15:31
Question What compilers can we use in Ansys Fluent to compile our UDF?
Roh
Roh is on a distinguished road
Guys,
I think title of the thread is clear that what's my question.
I read something about compiling UDF e.g.:
https://www.sharcnet.ca/Software/Ans...compilers.html
But for Windows OS they just talk about Microsoft visual studio. I'm using Ansys 19 and my OS is windows. Can I use other compilers? for example GCC?
Roh is offline   Reply With Quote
Old   September 2, 2018, 00:37
blackmask will become famous soon enough
The answer is YES. However you might need to manually write your own Makefile or build the dynamic library by hand. Believe it or not, it is not worth it. It is much easier to work under *nix, rather than mock the process in win*.
Roh and SphericalCube like this.
blackmask is offline   Reply With Quote
Old   September 3, 2018, 05:38
pakk will become famous soon enough
Originally Posted by blackmask View Post
The answer is YES.
To be clear: this is the answer to the question "Can I use other compilers?"
And I agree with blackmask. It is possible to use other compilers in Windows, but if you have to ask this question, you will need a lot of help to set everything up so that it really works, and it is much easier to just use the (freely available) Microsoft compiler.
Roh likes this.
pakk is offline   Reply With Quote
Old   September 10, 2018, 02:24
gearboy is on a distinguished road
Originally Posted by Roh View Post
Guys,
I have developed a tool to convert the default Fluent compiler from VC to GCC. Here the allowed attachment size is too small. Contact me if you need.
Roh likes this.
gearboy is offline   Reply With Quote
Old   September 11, 2018, 14:28
Roh
Thank you,
I wanted to use another compiler because VS is huge and take much space of the memory. May I know what compiler do you use? how do you set it up?
Old   September 11, 2018, 16:42
Thank you,
From the post that you replied to:
So on behalf of gearboy I can say: yes, you may know that the new compiler is GCC.
Old   September 11, 2018, 21:59
Right, we recommend tdm-gcc 4.9.2. After conversion of the compiling environment, you can compile udf same way as VC compiler.
Roh likes this.
Old   September 12, 2018, 01:53
Question
Roh
Attachment 65557
Thank you,
You have a PM from me. I use Ansys 19, Did you chack your tool to know if it has any problem with higher version of Ansys?
Old   September 12, 2018, 02:00
Smile
Roh
Attachment 65557
Sorry for bouble post but just wanted to ask Did you check the last version of tdm-gcc? Isn't there any problem if I get the last version? currently the last version is 5.1.0.2
http://tdm-gcc.tdragon.net/download
Old   September 13, 2018, 04:59
Please give me some time to upgrade it to support fluent19.0. Currently, it only support up to 18.2. For TDM-GCC, we recommend you use 4.9.2 and do not check server for upgrading when installing. Other versions may not work. Anyway, you can try the lastest TDM-GCC version and tell me if it works.
Old   September 13, 2018, 05:21
Roh
How much it will take time?
waiting to recieve it.
Old   October 7, 2018, 01:50
We have upgraded UdfMinGW to version 19.2, which support fluent 6.3-19.2. Please read the manual in the zip package first.
https://vcudfstudio.bitbucket.io/dow...fMinGW19.2.zip
Roh likes this.
Old   October 7, 2018, 03:56
Smile
  #13
Roh
Thank you.
I uploaded the file in somewhere eles for other fellas because I had problem to download it(not good server).
http://www.mediafire.com/file/72tljt...W19.2.zip/file
I tried everything that you said and it worked very well. A screenshot
Thank you so much.
I have a question:
If we have a workbench project and there is a fluent project in our workbench, how we have to use this program?
Old   October 8, 2018, 04:04
Thank you.
Thank you so much.
I have a question:
I guess you have to add C:\TDM-GCC-64\bin to PATH environment variable first (say your GCC installing folder is C:\TDM-GCC-64).
Old   October 15, 2018, 02:54
Question
  #15
Roh
You guess? Could you please add more details about your approach here? or maybe it could be better to check it at first and inform us because you know what's going on in this tool.
And a suggestion,
I don't know if you want to release your program as an open source project but you can use github.com
Old   January 5, 2019, 05:40
Question
  #16
Roh
gearboy,
I'm trying to compile a UDF but get this error:
The error:
Copied F:\RDE\Rotating Detonation Engines- UDF.c to libudf\src user_nt.udf file is outdated. So, recreating the file for 2ddp ...
(chdir "libudf\win64\2ddp")nmake: Nothing to be done for 'clean'.
nmake: *** No rule to make target '../../src/Rotating', needed by 'Rotating'. Stop.
(system "copy "C:\PROGRA~1\ANSYSI~1\v192\fluent"\fluent19.2.0\sr c\udf\makefile_nt.udf "libudf\win64\2ddp\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\2ddp")nmake: *** No rule to make target '../../src/Rotating', needed by 'Rotating'. Stop.
Done.
What's the matter with it?
Old   January 5, 2019, 14:32
Question
  #17
Roh
Solved the problem and got a new error and have fallen in a new problem. Here is the new error:
Error: received a fatal signal (Segmentation fault).
Error Object: #f
I managed to compile and load the UDF. Here is the report that I got after compilation:
Creating user_nt.udf file for 2ddp ... (system "copy "C:\PROGRA~1\ANSYSI~1\v192\fluent"\fluent19.2.0\sr c\udf\makefile_nt.udf "libudf\win64\2ddp\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\2ddp")# Generating ud_io1.h
../../src/NewUDF.c: In function 'vel':
../../src/NewUDF.c:42:13: warning: variable 'To_in' set but not used [-Wunused-but-set-variable]
real T_in, To_in;
../../src/NewUDF.c:41:13: warning: variable 'po_in' set but not used [-Wunused-but-set-variable]
real p_in, po_in;
# Generating udf_names.c because of makefile NewUDF.o
# Linking libudf.dll because of makefile user_nt.udf udf_names.o NewUDF.o
#########UDF source has been compiled with UdfMinGW(ver 19.2)#########
###Please visit https://vcUdfStudio.bitbucket.io for latest version###
Done.
The UDF is compiled and loaded successfully but when I want to initialize the project I got that error.
Old   November 11, 2021, 17:03
Juan Antonio Blanco
EngJuanAntonioBlanco is on a distinguished road
Hi friend, I have fluent 6.3.26 on Windows 10, I prove a lot of times compiled my udf, but I think that is impossible ... I prove with VS 19, VS 17, VS Express 12... What is the correct? If you can give me another option I´ve really been enjoying that.
Thanks in advance,
Eng. Juan Antonio Blanco
EngJuanAntonioBlanco is offline   Reply With Quote
Old   November 11, 2021, 21:01
Out of curiosity: why Fluent 6? That is like ten years old... You are missing out on a lot of updates! Compiler support has improved a lot since that version!
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
Old   November 11, 2021, 22:09
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
Thanks in advance,
VS Express 10
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
UDF velocity inlet. Different values (compile - Fluent) asking FLUENT 0 July 13, 2018 18:02
UDF Defining in ANSYS FLUENT 16.2 in Win 10 Sadegh.A Fluent UDF and Scheme Programming 11 February 15, 2017 15:45
Problem in compiling UDF with ANSYS Fluent 17.1 and Visual Studio 14.0 Spiker54321 Fluent UDF and Scheme Programming 2 October 27, 2016 10:09
Fluent 6.3.26 on Linux does not compile an UDF Entwistle Fluent UDF and Scheme Programming 1 March 4, 2014 15:49
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
