temperature gradient
Like Tree2Likes
  • 2 Post By `e`
Old   June 13, 2018, 14:51
Default temperature gradient
Animesh Sahoo
sahoo is on a distinguished road
hello everyone,
Actually I am trying to solve the transport equation, as given in the attachment. So, I have made 2 UDS which has also been attached. I just want to know how to include gradient with respect to temperature.
The code for UDS are as follows:-
UDS0 :-
DEFINE_DIFFUSIVITY(teg_diffusivity, cell, thread, i)
real res;
real temp = C_T(cell, thread);
res = -3.982 * pow(CON,-5) + 2.98 * pow(CON,-7) * temp - 4.685 * pow(CON,-10) * pow(temp,2) + 2.51 * pow(CON,-12) * pow(temp,3);
real res1 = 1 / res;
return res1;
UDS1 :-
DEFINE_SOURCE(teg1_source, c, t, dS, eqn)
real temp = C_T(c,t);
dS[eqn] = grad((8.439 * pow(CON,-4) - 3.81 * pow(10,-6) * temp + 6.736 * pow(CON,-9) * pow(temp,-9) - 3.934 * pow(CON,-12) * pow(temp,-12))*grad(temp));
return (8.439 * pow(CON,-4) - 3.81 * pow(10,-6) * temp + 6.736 * pow(CON,-9) * pow(temp,-9) - 3.934 * pow(CON,-12) * pow(temp,-12))*grad(temp);
Please help me, I am a beginner and I need it desperately for my project.
sahoo is offline   Reply With Quote
Old   June 13, 2018, 21:35
`e`
`e` is on a distinguished road
The temperature gradient is retrieved with C_T_G(c,t) which is a vector with components in each direction, and the magnitude can be calculated with NV_MAG(C_T_G(c,t)).
Further reading: UDF temperature gradient
`e` is offline   Reply With Quote
Old   June 14, 2018, 04:13
Animesh Sahoo
Thanks 'e' for replying ,
Can you just tell me, if I have a property as a function of temperature(like the one I have attached) and I need gradient of that function then can I simply use grad(function) ?
And also tell if you know the code for finding differential of function with respect to different variables.
Old   June 14, 2018, 04:59
`e`
First of all, determine which equations you would like to solve, and provide some further details. Remember that the nabla symbol means that you are differentiating the variable in each spatial direction, for example in three dimensions:
\nabla T = \frac{\partial T}{\partial x}\mathbf{i} + \frac{\partial T}{\partial y}\mathbf{j} + \frac{\partial T}{\partial z}\mathbf{k}
Each term corresponds to C_T_G(c,t)[0], C_T_G(c,t)[1] and C_T_G(c,t)[2]. For details, read section "3.2.3.7. Gradient (G) and Reconstruction Gradient (RG) Vector Macros" (for R15.0) in the UDF manual.
For the example you provided with \alpha(T), you could differentiate with respect to T analytically. What different variables are you referring to?
Old   June 14, 2018, 05:24
Animesh Sahoo
Hey thanks again,
Actually I was trying to include the R.H.S of the equation (attached) in source of UDS0 and I know the alpha in the equation as a function of temperature. So, I made the code as follows :-
static real CON = 10;
dS[eqn] = grad((8.439 * pow(CON,-4) - 3.81 * pow(10,-6) * temp + 6.736 * pow(CON,-9) * pow(temp,-9) - 3.934 * pow(CON,-12) * pow(temp,-12)) * C_T_G(c,t));
return (8.439 * pow(CON,-4) - 3.81 * pow(10,-6) * temp + 6.736 * pow(CON,-9) * pow(temp,-9) - 3.934 * pow(CON,-12) * pow(temp,-12)) * C_T_G(c,t);
But it wont work. So, I was a bit confused between gradient and differential. But now I understood what you explained. Can you just post the correct code for the above equation, it will be very helpful.
Old   June 14, 2018, 07:47
`e`
If your source term is \frac{\partial}{\partial x} \left( \alpha(T) \frac{\partial T}{\partial x}\right) then you could create a user-defined scalar (UDS) for \alpha(T) \frac{\partial T}{\partial x} using:
C_UDSI(c,t,0) = alpha_function(C_T(c,t))*C_T_G(c,t)[0];
within a loop, and creating a function for alpha. For example:
real alpha_function(real T) {
	return 8.439e-4 - 3.81e-6*T + 6.736e-9*pow(T,-9.) - 3.934e-12*pow(T,-12.);
where e-4 means *10^-4 or *pow(10,-4). Lastly, the source term can be evaluated with C_UDSI_G. Read through the examples in "8.2.5. User-Defined Scalars" (for R15.0) in the UDF manual for further guidance.
Note: you would need two other UDS for the y and z components (remember to take the gradients in the y and z directions respectively).
ray_lo and FelixS like this.
Old   June 14, 2018, 09:05
Animesh Sahoo
Thank you very much I got it.
How to create a temperature gradient in thin wall and two dimensions leggman7 Main CFD Forum 0 October 30, 2013 00:21
How to get temperature gradient in dat.file jason feng FLUENT 0 September 30, 2013 00:39
Wall correction for the temperature gradient Hagen OpenFOAM 0 March 7, 2011 21:04
temperature normal gradient on a boundary Sandrine Main CFD Forum 2 June 10, 2009 17:34
Direct calculation of temperature gradient J.W.Ryu FLUENT 5 December 27, 2001 07:39
