How to modify some results given by Fluent using udf |
April 7, 2018, 12:59 |
youhane kha
Rep Power: 9 |
Hello everybody,
I have modelled moisture within fluent using the Species model. The model works perfectly, but when I display the contours of relative humidity, sometimes it exceeds 100 % when the humid air passes next to a cold wall like in this picture: That is normal, because Fluent use a mathematical formula to calculate the relative humidity, but what I want now is to ask if I can write an udf to modify the results of relative humidity as follows: IF (RH > 100) --> Rh = 100. Can anyone helps me with that please ? |
April 8, 2018, 22:32 |
Alexander
Rep Power: 34 |
In Fluent GUI:
results -> graphics -> contours -> switch off auto range option -> put 100 in Max best regards |
April 9, 2018, 08:54 |
youhane kha
Rep Power: 9 |
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle | FelixJJ | FLUENT | 2 | October 20, 2021 03:39 |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 10:07 |
Fluent Radiation/porous media | Schmitt pierre-Louis | FLUENT | 26 | September 1, 2016 11:29 |
fluent udf problem: write specific data for every iteration in a file. | nnvoro | Fluent UDF and Scheme Programming | 1 | May 27, 2013 16:26 |
UDF problem caused by various version of Fluent | Yurong | FLUENT | 3 | January 15, 2006 11:57 |
