Scheme programming-read multiple data files from transient computations |
Anuja Vijayan
Rep Power: 9 ![]() |
Hello Friends,
I have some 1000+ data files and a few case files generated after a transient calculation. I saved the case files only when it got modified. Therefore, the normal scheme command (Do ((x 1 (+ x 1))) ((> x 1000)) (ti-menu-load-string (format #f "file read-case-data C:\Users\Anuarun\File\Case17_Trial2-1-0000~a.cas.gz o" x)); ) is not working in my case. I want to read each data file, create an iso surface of vapour volume fraction and then plot/write the value of pressure on the iso surface on to a .txt file for all cases. Is there a way to do this? I am quite familiar with journal files, but have never worked with scheme programming. Any help is greatly appreciated. |
Alexander
Rep Power: 34 ![]() ![]() |
(Do ((x 1 (+ x 1))) ((> x 1000)) (ti-menu-load-string (format #f "file read-case-data C:\Users\Anuarun\File\Case17_Trial2-1-0000~a.cas.gz o" x)); ) Code:
ti-menu-load-string Than put all of than into scheme for instance, to read data, noct case you need to run read-data tui command in scheme it will be Code:
(ti-menu-load-string (format #f "file read-data C:\Users\Anuarun\File\Case17_Trial2-1-0000~a.dat o" x)) best regards |
Anuja Vijayan
Thank you AlexanderZ.
Since it was very urgent, I wrote a python pgm to call a .jou repeatedly to get the work done. Anyway, I will try this way and get back to you. Thank you so much! Regards, Anu |
renhaitao
Rep Power: 0 ![]() |
Excuse me, can you tell me how you operate data files through journal or scheme ?Thank you so much!
How to read transient velocity profile data as inlet condition at each time step | hemmt | FLUENT | 12 | July 9, 2018 02:26 |
Exporting data of transient simulation DURING a simulation, at user locations ? | Milan2013 | CFX | 0 | April 18, 2014 03:47 |
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 13:39 |
Transient solution multiple CGNS files in Tecplot | Ramses Galaz | Tecplot | 3 | October 17, 2006 10:43 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
