March 27, 2018, 19:21 |
F_UDMI versus C_UDMI
Matt
Rep Power: 8 |
I'd like to know how different the application of F_UDMI and C_UDMI is. In DEFINE_DPM_EROSION example of the manual:
F_UDMI(f,t,AVG_DIAMETER) = (P_DIAM(p) + num_in_data * F_UDMI(f,t,AVG_DIAMETER)) / (num_in_data + 1); C_UDMI(c0,t0,AVG_DIAMETER) = F_UDMI(f,t,AVG_DIAMETER); /* Average velocity normal to wall of particles hitting the wall:*/ F_UDMI(f,t,AVG_RADI_VELO) = (vel_ortho + num_in_data * F_UDMI(f,t,AVG_RADI_VELO)) / (num_in_data + 1); C_UDMI(c0,t0,AVG_RADI_VELO) = F_UDMI(f,t,AVG_RADI_VELO); F_UDMI(f, t, NUM_OF_HITS) = num_in_data + 1; C_UDMI(c0,t0,NUM_OF_HITS) = num_in_data + 1; F_UDMI value is copied to C_UDMI. Why is that necessary? Thanks |
March 28, 2018, 05:08 |
Rep Power: 26 |
F_UDMI(f,t) is the value of the UDM on a face.
C_UDMI(c,t) is the value of the UDM in a cell. In your example, the "Average velocity normal to wall of particles hitting the wall" is calculated on wall faces (which is the most logical thing to do). For some reason unknown to me, this information also needs to be available on the cell closest to the wall, the the programmer copied this information. |
March 28, 2018, 09:45 |
Matt
Rep Power: 8 |
Thanks for your response. I find this example of the manual very confusing!
While at it, I'm not able to use the DEFINE_ON_DEMAND(reset_UDM) for resting my UDM's . It gives an error. DEFINE_ON_DEMAND(reset_UDM) { /* assign domain pointer with global domain */ domain = Get_Domain(1); reset_UDM_s(); } Does this code work for only this example? if not what changes I need to make? The way I reset my UDM's right now is to loop through all cells and make their values equal to zero: thread_loop_c(t,d) { begin_c_loop(c,t) { for(i=0;i<7;i++) C_UDMI(c,t,i)=0.0; } end_c_loop(c,t) } |
March 28, 2018, 09:50 |
Rep Power: 26 |
In the example in the manual, the function "reset_UDM_s" is defined. And their definition is essentially what you are also doing.
"reset_UDM_s" is not an internal Fluent function, you have to write it (or copy it from the manual). |
March 28, 2018, 10:07 |
Matt
Rep Power: 8 |
Now it make sense Thanks . I have another question then. In that part of the code where "reset_UDM_s" is defined:
void reset_UDM_s(void) { Thread *t; cell_t c; face_t f; int i; ..... "t" is used for both cell thread and face thread. Thread_loop_f (t, domain) and Thread_loop_c(t, domain). Are they the same thing?! |
March 28, 2018, 10:11 |
Rep Power: 26 |
Yes, both are threads.
March 28, 2018, 10:18 |
Matt
Rep Power: 8 |
If they both are the same thing, then why t0 is defined later in DEFINE_DPM_EROSION. Why not use t for both F_UDMI and C_UDMI?
March 28, 2018, 10:26 |
Rep Power: 26 |
Because in DEFINE_DPM_EROSION, they want to use two threads at the same time, one for a cell and one for a face. So you need two different thread variables.
In reset_UDM_s, first the thread t is used for face threads, then for cell threads. Never for two at the same time. Still, the programmer could have used two different thread variables for this, the cost for this (memory-wise) would be negligible (or maybe even non-existent if the compiler is smart enough). It's just a choice. |
March 28, 2018, 12:05 |
#9 |
Matt
Rep Power: 8 |
I have the following code to calculate the number of particles hitting a boundary and save it to a C_UDMI. It works fine and I can plot the C_UDMI contour
DEFINE_DPM_BC(OSU_Deposition_Model_R1,p,t,f,f_norm al,dim) { #if !RP_HOST Thread *tcell=P_CELL_THREAD(p); cell_t c=P_CELL(p); Domain *d; d=Get_Domain(1); C_UDMI(c,tcell,0) += 1.; return PATH_ABORT; #endif } But if I try to save the same information in a F_UDMI. I get 0 value everywhere when I plot the user defined memory contour: DEFINE_DPM_BC(OSU_Deposition_Model_R1,p,t,f,f_norm al,dim) { #if !RP_HOST Domain *d; d=Get_Domain(1); // Thread *t; // face_t f; F_UDMI(f,t,0) += 1.; return PATH_ABORT; #endif } I saw your response to this in "define_profile and F_UDMI" thread. Is it just a bug in FLUENT or is there any way to plot F_UDMI? |
March 29, 2018, 03:30 |
#10 |
Rep Power: 26 |
I don't know if it is a bug, but I considered it as "unexpected behavior".
July 14, 2021, 04:55 |
#11 |
WB
Rep Power: 5 |
July 14, 2021, 14:49 |
#12 |
Rep Power: 26 |
No. Why do you need my email address to ask a question??? Just so it here.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build". |
dpm model, udf and programming, user defined memory |
How to Plot Average Temperature or Other Variables of a Domain Versus Pipe n CFD-Post | Shomaz ul Haq | CFX | 8 | June 6, 2018 18:43 |
[General] Problem of plotting Nusselt number versus length of tube using Paraview | princexypn89 | ParaView | 2 | May 11, 2016 12:33 |
Plot of Solid Volume Fraction versus Height | Musa | FLUENT | 2 | February 5, 2012 08:06 |
Properties of air versus temperature AND pressure | Vincent | Main CFD Forum | 5 | July 28, 2008 06:28 |
variable versus time | Cesare | CFX | 1 | September 27, 2004 11:00 |
