simple UDF doesn't read input from external file. interprets/compiles without errors |
March 22, 2018, 03:44 |
ahmad
Rep Power: 8 |
HI, I am trying to write a UDF, which reads data(temperature values) from an external (.dat) file. (saved in the same location as the UDF). It also needs to write the data in another file in the same folder. UDF interprets/compiles without any error. But doesn't store or reads data from/into the input/output files. UDF is written below.
#include "udf.h" DEFINE_PROFILE(wall_2, thread, index) { real x[ND_ND]; face_t f; int count,i; real w,a,b; FILE *fpp; FILE *fp; fpp=fopen("MianT2.dat","w+"); fp=fopen("MianT.dat","r+"); count=0; begin_f_loop(f,thread) { count=count+1; fscanf(fp,"%d %f %f %f",&i,&a,&b,&w); F_CENTROID(x,f,thread); F_PROFILE(f,thread,index)=w; fprintf(fpp,"%d %f %f %f/n",count,x[0],x[1],w); } end_f_loop(f,thread) fclose(fpp); fclose(fp); } read file(mianT.dat) has 4 coloumns. any help would be highly appreciated, I have already spent days trying to resolve these issues, but in vain. Last edited by ahmad_xjtu; March 22, 2018 at 03:46. Reason: missing line |
March 22, 2018, 05:08 |
Rep Power: 27 |
Add checks to see if the files open:
fpp=fopen("MianT2.dat","w+"); fp=fopen("MianT.dat","r+"); if (!fpp) {Message("Can not open MianT2.dat for writing!");exit(1);} if (!fp) {Message("Can not open MianT.dat for reading!");exit(1);} |
March 22, 2018, 05:25 |
ahmad
Rep Power: 8 |
Thank you so much for the response.
I am new to UDF's and never tried C language either. though I can handle fortran. Did you mean to add these lines in code and interpret the udf? I tried interpreting in fluent and it gave the following error. Error: I:\\fluent_external_reciever\\external_files\\dp0\ \FFF\\Fluent\\source.c: line 12: invalid type for negation: pointer to void. attached herewith are data from read and write files. It creates and writes something in the output file, but not what I am expecting. first 20 entries of the write file 1 60.764812 81.775528 0.000000 2 60.764812 77.975975 0.000000 3 60.764812 81.175499 0.000000 4 60.764812 81.375465 0.000000 5 60.764812 80.975525 0.000000 6 60.764812 76.975876 0.000000 7 60.764812 81.775528 0.000000 8 60.764812 81.575439 0.000000 9 60.764812 81.775520 0.000000 10 60.764812 81.775513 0.000000 11 60.764812 80.775558 0.000000 12 60.764812 77.975975 0.000000 13 60.764812 81.775513 0.000000 14 60.764812 80.575584 0.000000 15 60.764812 81.175491 0.000000 16 60.764812 81.375458 0.000000 17 60.764812 76.975868 0.000000 18 60.764812 81.775505 0.000000 19 60.764812 81.575432 0.000000 20 60.764812 80.375618 0.000000 and similarly for the read file, 1 0.1 4.9 594.124 2 0.1 4.7 596.741 3 0.1 4.5 600.5 4 0.1 4.3 604.18 5 0.1 4.1 607.712 6 0.1 3.9 610.96 7 0.1 3.7 613.945 8 0.1 3.5 616.58 9 0.1 3.3 618.823 10 0.1 3.1 620.638 11 0.1 2.9 621.967 12 0.1 2.7 622.792 13 0.1 2.5 623.153 14 0.1 2.3 622.964 15 0.1 2.1 622.281 16 0.1 1.9 621.086 17 0.1 1.7 619.423 18 0.1 1.5 617.32 19 0.1 1.3 614.779 20 0.1 1.1 611.87 thank you. |
March 22, 2018, 06:36 |
Rep Power: 27 |
No, I meant compile.
By the way: your original post said "But doesn't store or reads data from/into the input/output files.". The most recent post said "It creates and writes something in the output file, but not what I am expecting." These are two different outcomes than point to different solutions. |
March 22, 2018, 09:22 |
ahmad
Rep Power: 8 |
yeah, my apologies for making it confusing. Please consider the most recent post, i.e. not having the desired output.
I compiled the code as you suggested.Everything remains the same. The same output as in my last post. This appears as UDF compiles. Copied I:\fluent_external_reciever\external_files\dp0\FFF \Fluent\source.c to libudf\src Creating user_nt.udf file for 3ddp ... (system "copy "C:\PROGRA~1\ANSYSI~1\v150\fluent"\fluent15.0.0\sr c\makefile_nt.udf "libudf\win64\3ddp\makefile" ") 1 file(s) copied. (chdir "libudf")(chdir "win64\3ddp")# Generating ud_io1.h source.c # Generating udf_names.c because of makefile source.obj udf_names.c udf_names.c(8) : warning C4113: 'void (*)()' differs in parameter lists from 'void (*)(void)' # Linking libudf.dll because of makefile user_nt.udf udf_names.obj source.obj Microsoft (R) Incremental Linker Version 10.00.30319.01 Copyright (C) Microsoft Corporation. All rights reserved. Creating library libudf.lib and object libudf.exp Done. Thank you again for taking time to review my problem. |
March 23, 2018, 03:03 |
ahmad
Rep Power: 8 |
I kept playing with it and here's an update.
I created another file, put all the values of the input file into that new file and loaded this new file. its really strange and weird but I am now getting the right values for temperature. Last edited by ahmad_xjtu; March 24, 2018 at 08:52. Reason: update |
udf input file, udf read |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 09:46 |
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 18:25 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 10:07 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 18:18 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 06:18 |
