March 12, 2018, 03:01 |
temperature gradient in a microchannel
Phil
Rep Power: 13 |
#include "udf.h" #include "mem.h" #include "sg.h" DEFINE_PROFILE(temp_slip, t, position) { real x[ND_ND]; real y,T_wf,T_wc,T_wc_g; face_t f; cell_t c; begin_f_loop(f,t) { y = x[1]; T_wf = F_T(f,t); T_wc = C_T(c,t); T_wc_g = C_T_G(c,t)[0]; F_PROFILE(f, t, position) = 330.0 + 0.001*T_wc; /* printf("%d %d %d \n",y,T_wf,T_wc); */ printf("%d %d %d %d\n",y,T_wf,T_wc,T_wc_g); } end_f_loop(f,t) } =============== I tried to apply the temeperature gradient in a vertical retangulare wall. First, I tried to see what values are comunicating along the boundary UDF progem and main ANSYS Fuent. Without the C_T_G line I got the results. However, the values y,T_wf,T_wc are so big or zero. Anyway the solution converged. Next, I insert the C_T_G line. I got the error message like below Error: received a fatal signal (Segmentation fault). Erro Object: #f What happened? Based on the previous questions, I tried pre-iterations and solve/set/expert implimentation. Please help me. Thanks |
March 12, 2018, 06:26 |
Alexander
Rep Power: 34 |
from your code
T_wf = F_T(f,t); T_wc = C_T(c,t); T_wc_g = C_T_G(c,t)[0]; why do you have Code:
begin_f_loop(f,t) { from your code Code:
real x[ND_ND]; real y; ..... y = x[1]; and than asked y to be equal to x[1]. What value is stored in x[1]? In Ansys fluent customization manual pay attention to: Code:
begin_c_loop(c,t) F_CENTROID(x,f,t); C_CENTROID(x,c,t); Code:
Error: received a fatal signal (Segmentation fault). Erro Object: #f Debug code without C_T_G first, than add it. best regards |
March 12, 2018, 22:31 |
Phil
Rep Power: 13 |
Thanks a lot.
================================== what are f and c in brackets (f,t) , (c,t) from your point of view? ================================== In a 2d domain, (f,t) , (c,t) are locations of face(f) and cell(c), respectively. ================================== why do you have Code: begin_f_loop(f,t) { for f, but nothing for c ? ================================== I want to apply temperature gradient boundary conditions along the wall which means the boundary face. I changed "f" to "c". ================================== from your code Code: real x[ND_ND]; real y; ..... y = x[1]; here you've defined x as 2D or 3D array (depends on your case) and than asked y to be equal to x[1]. What value is stored in x[1]? ================================== For the values of y,T_wf,T_wc,T_wc_g 1633131590 0 0 0 -42712596 0 0 0 -1718845012 0 0 0 899989867 0 0 0 -775854318 0 0 0 1842980562 0 0 0 165406993 0 0 0 ================================== In Ansys fluent customization manual pay attention to: Code: begin_c_loop(c,t) F_CENTROID(x,f,t); C_CENTROID(x,c,t); Regarding C_T_G, may be you need pre-iteration approach ================================== I got no error message. |
March 12, 2018, 22:32 |
Phil
Rep Power: 13 |
#include "udf.h"
#include "mem.h" #include "sg.h" DEFINE_PROFILE(temp_slip, t, position) { real x[2]; real y,T_wf,T_wc,T_wc_g; face_t f; cell_t c; begin_c_loop(c,t) { F_CENTROID(x,f,t); C_CENTROID(x,c,t); y = x[1]; T_wf = F_T(f,t); T_wc = C_T(c,t); /* T_wc_g = C_T_G(c,t)[0]; */ F_PROFILE(f, t, position) = 330.0 + 0.001*T_wc; /* printf("%d %d %d \n",y,T_wf,T_wc); */ printf("%d %d %d %d\n",y,T_wf,T_wc,T_wc_g); } end_c_loop(c,t) } |
March 13, 2018, 00:38 |
Alexander
Rep Power: 34 |
you code has errors
In Ansys fluent customization manual pay attention to: Code: Code:
begin_f_loop(f,t) begin_c_loop(c,t) F_CENTROID(x,f,t); C_CENTROID(x,c,t); |
March 14, 2018, 01:37 |
Phil
Rep Power: 13 |
Thanks for the quick reply AlexanderZ.
To make sure the variables between UDF and Fluent, I printed the cordinates, boundary wall temperature, and F_PROFILE. As you see below numbers, these numbers are wrong. What happened? ==================================== #include "udf.h" #include "mem.h" #include "sg.h" DEFINE_PROFILE(temp_slip, t, position) { real x[ND_ND]; real y1,y2,T_wc,T_wc_g; cell_t c; begin_c_loop(c,t) { C_CENTROID(x,c,t); y1 = x[1]; y2 = x[2]; T_wc = C_T(c,t); /* T_wc_g = C_T_G(c,t)[0]; */ F_PROFILE(c, t, position) = 330.0 + 0.001*T_wc; printf("%d %d %d %d\n",y1,y2,T_wc,F_PROFILE(c, t, position)); } end_c_loop(c,t) } ==================================== -1928693984 -1928693984 142152092 142152092 690429126 690429126 142152092 142152092 -985703290 -985703290 142152092 142152092 1633131590 1633131590 142152092 142152092 -42712596 -42712596 142152092 142152092 -1718845012 -1718845012 142152092 142152092 899989867 899989867 142152092 142152092 -775854318 -775854318 142152092 142152092 1842980562 1842980562 142152092 142152092 165406993 165406993 142152092 142152092 ==================================== |
March 14, 2018, 02:57 |
Alexander
Rep Power: 34 |
it is recommended to use Message macros instead of printf function
In Ansys Fluent Customization Manual go to chpter 3.7. Input/Output Macros there you may fined detailed information about input/output In your last version code you've used %d macros for output. However, %d is used for integers only, but you want real. So you need %f code was Code:
printf("%d %d %d %d\n",y1,y2,T_wc,F_PROFILE(c, t, position)); Code:
Message("%f %f %f %f\n",y1,y2,T_wc,F_PROFILE(c, t, position)); |
March 14, 2018, 08:55 |
Rep Power: 12 |
Hi Pittsb,
Your original code assumed that it had access to both (c,t) and (f,t) -- which is not possible: a Thread *t pointer can be a cell-thread pointer or a face-thread pointer, but not both at once. Also, c was never assigned a value. (I'm repeating or rephrasing what AlexanderZ has already pointed out.) Your latest code is passed the thread pointer t, and assumes that it can access cell values. This seems unlikely to me: DEFINE_PROFILE is typically applied as a boundary condition, and therefore applied to a face zone, so t will be a face-thread pointer. You might not get errors from the latest code, because the storage of cells in a cell-thread is the same as faces in a face-thread, and the loops are the same. But still, it is dangerous to be so unclear. For example, you have chance of reaching C_T_G(c,tc), but you have no chance of reaching F_T_G(f,tf) or C_T_G(f,tf). I have used tf instead of t for a face-thread pointer, and tc for a cell-thread pointer -- this is very useful notation to remind yourself which is which. If you need access to the cell that a face (f,tf) is part of, then you need: Thread *ct; cell_t c; ct = F_C0_THREAD(f,tf); c = F_C0(f,tf); (And as soon as you use F_C0, you should wonder whether you actually wanted the cell on the other side of the face: F_C1,F_C1_THREAD. In this case, we might be sure that these are boundary faces, in which case there can be only one cell, and it will always be C0.) Good luck! Ed |
March 20, 2018, 00:23 |
#9 |
Phil
Rep Power: 13 |
Thanks a lot for explaining the face and the cell. Now, I decided to focus on the face which is a wall boundary. Without this line " T_wf_g = F_T_G(f,tf)[0]; " which represents "dT/dx", the results looks good. With F_T_G command, I got the error message "error C2109: subscript requires array or pointer". What happened?
=========================================== #include "udf.h" #include "mem.h" #include "sg.h" DEFINE_PROFILE(temp_slip, tf, position) { real x[2]; real y1,y2,T_wf,T_wf_g; face_t f; /* Thread *ct; ct = F_C0_THREAD(f,tf); c = F_C0(f,tf); */ begin_f_loop(f,tf) { F_CENTROID(x,f,tf); y1 = x[0]; y2 = x[1]; T_wf = F_T(f,tf); T_wf_g = F_T_G(f,tf)[0]; F_PROFILE(f, tf, position) = 330.0 + 0.001*T_wf_g; Message("%f %f %f %f\n",y1,y2,T_wf,T_wf_g); } end_f_loop(f,tf) =========================================== Last edited by pittsb; March 20, 2018 at 20:17. |
March 22, 2018, 10:03 |
#10 |
Rep Power: 12 |
Hi Pittsb,
What happened is that F_T_G does not exist. (Sorry, it was me who first mentioned F_T_G, in the context of things that are not possible. Perhaps I should have mentioned just how hopeless that quest is: completely.) Your compiler's error message does not say this, perhaps because the compiler still has some hope that you will define it later, during linking or something. But the compiler is sure that you need to define it as an array if you refer to F_T_G(f,tf)[0]. In an ideal world, there would be documentation of what variables are sometimes available in Fluent UDFs, and how you should check whether they are available, and so on. This is not an ideal world. You can see that C_T_G exists, because it is defined in one of the header files (specifically, mem.h) that are part of a standard Fluent installation. The fact that F_T_G does not exist in the header files definitely indicates that Fluent simply does allow you to access gradient values at faces, probably because it does not store those values there, and possibly does not even calculate them. If you want a gradient there, you will need to use the local cell version, or calculate one for yourself. (At first sight, this sounds fairly simple, in principle. It might turn out to be difficult once you consider all the edge cases -- I'm not sure.) Good luck! Ed |
Access to temperature gradient C_T_G | cfdstar | Fluent UDF and Scheme Programming | 15 | December 13, 2020 19:27 |
Temperature gradient for the internal Field. | Philipp Dietrich | OpenFOAM Programming & Development | 0 | July 2, 2014 04:15 |
How to create a temperature gradient in thin wall and two dimensions | leggman7 | Main CFD Forum | 0 | October 30, 2013 00:21 |
How to get temperature gradient in dat.file | jason feng | FLUENT | 0 | September 30, 2013 00:39 |
Direct calculation of temperature gradient | J.W.Ryu | FLUENT | 5 | December 27, 2001 07:39 |
