Error undeclared variable
Like Tree2Likes
  • 1 Post By AlexanderZ
Old   March 7, 2018, 23:37
Default Error undeclared variable
Andre Kurniawan
andrk is on a distinguished road
Hi everyone,
I want to interpret a udf file to ansys fluent 15, but i encounter this error:
"line 29: ads: undeclared variable"
Here is my code (I have bolded the line 29):
#include "udf.h"
DEFINE_ADJUST(adsorption,domain)
Thread *t;
cell_t c;
real E,A,P;
thread_loop_c(t,domain)
begin_c_loop(c,t)
real tem=C_T(c,t);
P=C_P(c,t)+RP_Get_Real("operating-pressure");
E=3080+18.9*tem;
A=8.31429*tem*log(1.47E9/P);
C_UDSI(c,t,ads)=71.6*exp(-A*A/(E*E));
end_c_loop(c,t)
DEFINE_ADJUST(q_ads, domain)
Thread *t;
cell_t c;
real dt;
begin_c_loop(c,t)
dt = RP_Get_Real("physical-time-step");
C_UDSI(c,t,q_ads)=C_UDSI_M1(c,t,q_ads)+0.15*dt*(C_ UDSI_M1(c,t,ads)-C_UDSI_M1(c,t,q_ads));
end_c_loop(c,t)
DEFINE_ADJUST(d_ads, domain)
Thread*t; cell_t c;
begin_c_loop(c,t)
C_UDSI(c,t,d_ads)=-0.532224*0.15*
(C_UDSI(c,t,ads)-C_UDSI(c,t,q_ads));
end_c_loop(c,t)
DEFINE_SOURCE(m_src,c,t,dS,eqn)
dS[eqn]=0.0;
return C_UDSI_M1(c,t,d_ads);
DEFINE_ADJUST(H_ads,domain)
Thread*t;
cell_t c;
real p_operating, p_static;
begin_c_loop(c,t)
C_UDSI(c,t,H_ads)=3080*
sqrt(log(71.6/C_UDSI_M1(c,t,ads)));
end_c_loop(c,t)
DEFINE_SOURCE(esrc,c,t,dS,eqn)
real e_source;
e_source=-C_UDSI_M1(c,t,d_ads)*
0.496056352e3*3080
*sqrt(log(71.6/C_UDSI_M1(c,t,ads)));
dS[eqn] = 0.0;
return e_source;
Hope someone can help me to solve it.
Many thanks!
andrk is offline   Reply With Quote
Old   March 8, 2018, 00:20
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
what is "ads" here? why do you use ads?
Best regards
annan likes this.
AlexanderZ is offline   Reply With Quote
Old   March 8, 2018, 05:13
Andre Kurniawan
Originally Posted by AlexanderZ View Post
Best regards
I want "ads" represent the absolute adsorption isotermal
represent this equation:
na = 71.6 * exp [-(A)^2/E^2]
Old   March 8, 2018, 09:56
pakk will become famous soon enough
Very nice that you want that, but how can the compiler know that?
You never tell the compiler what "ads" is...
Personally, I would just replace it by the number 0.
pakk is offline   Reply With Quote
Old   March 11, 2018, 10:01
Andre Kurniawan
I'm new at CFD software, my senior was using this code, so I don't know some, can you tell me how the compiler can read "ads"? Many thanks
Old   March 12, 2018, 00:13
Alexander
As pakk has mentioned, I think you should change ads or q_ads/d_ads to 0 everywhere in your udf code where UDSI is.
was
C_UDSI(c,t,ads)
to be
C_UDSI(c,t,0)
Old   March 14, 2018, 21:02
Andre Kurniawan
was
C_UDSI(c,t,ads)
to be
C_UDSI(c,t,0)
If I change that, then how to differentiate 4 same equations C_UDSI(c,t,0)? While I hsve to use in this equation
C_UDSI(c,t,d_ads)=-0.532224*0.15*(C_UDSI(c,t,ads)-C_UDSI(c,t,q_ads));
Will it work if just be the following equation?
C_UDSI(c,t,0)=-0.532224*0.15*(C_UDSI(c,t,0)-C_UDSI(c,t,0));
Old   March 14, 2018, 22:31
Alexander
to differentiate variables you need to use integer values, for instance
ads change to 0
d_ads change to 1 and so on
You may find more details in Ansys Fluent Customization manual
best regards
andrk likes this.
Old   March 15, 2018, 00:15
Andre Kurniawan
ads change to 0
best regards
Thank you so much, I'm really really newbie, it look likes very easy evidently, again, thank you so much
Old   August 13, 2020, 07:01
arun km
arun km is on a distinguished road
Did you resolve the issue
arun km is offline   Reply With Quote
udf code, udf error, udf undeclared variable
OpenFoam-1.6-ext Allwmake compilation error - one last barrier Pat84 OpenFOAM Installation 15 July 25, 2012 22:49
emag beta feature: charge density charlotte CFX 4 March 22, 2011 10:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 05:35
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
