Velocity UDF error
Like Tree1Likes
  • 1 Post By pakk
Old   January 8, 2018, 08:26
Default Velocity UDF error
Kamal Bisht
Bisht is on a distinguished road
I am using a linearly increasing velocity profile with time at the inlet. Here is UDf.
#include "udf.h"
DEFINE_PROFILE(velocity_magnitude, t, i)
real default_early_velocity_mag,default_late_velocity_m ag,velocity_mag;
real start_velocity,end_velocity;
real ramp_start,ramp_end;
real line_slope,the_current_time;
face_t f;
default_early_velocity_mag=0.01;
default_late_velocity_mag=0.1;
start_velocity=0.01;
end_velocity=0.1;
ramp_start=0.0;
ramp_end=45.0;
velocity_mag=default_early_velocity_mag;
the_current_time = CURRENT_TIME;
line_slope=(end_velocity-start_velocity)/(ramp_end-ramp_start);
if ((the_current_time>=ramp_start) && (the_current_time<=ramp_end))
velocity_mag=line_slope*the_current_time;
if ((the_current_time>ramp_end))
velocity_mag=default_late_velocity_mag;
begin_f_loop(f,t)
F_PROFILE(f,t,i) = velocity_mag;
end_f_loop(f,t)
The simulation is running okay for the first 35 seconds after that I got the error message.
Unable to parse: [free
Error: undefined read macro
Error Object: ()
Error: > (greater-than): invalid argument [2]: wrong type [not a number]
Error Object: #f
Halting due to end of file on input.
Ending computation
Any idea why is it happening?
Bisht is offline   Reply With Quote
Old   January 8, 2018, 10:02
pakk will become famous soon enough
No.
However, I suspect that you forgot one term:
velocity_mag = start_velocity + line_slope*the_current_time;
This causes a discontinuity in your boundary condition (it jumps at 45 s from 0.09 m/s to 0.10 m/s), but I don't expect that this causes the error that you see. Still good to fix it, though...
Bisht likes this.
pakk is offline   Reply With Quote
Old   January 8, 2018, 10:21
Kamal Bisht
Thanks for the highlighting the improvement.
Yeah it shouldn't create a problem at 35 seconds of physical time. I am using a journal file to run my simulation on cluster.
Could it be due to it?
Old   January 11, 2018, 10:29
obscureed is on a distinguished road
As pakk says, there isn't much wrong with the UDF (apart from the discontinuity -- well spotted!), so I would go looking at the journal. (Does the journal contain the word "free", as mentioned in the error message?)
There is one error in the UDF as listed: a space in the fourth line "default_late_velocity_m ag". But I would be surprised if the libudf compiled with that space there, so perhaps it just crept in during transfer to this forum.
obscureed is offline   Reply With Quote
Old   January 12, 2018, 02:53
Kamal Bisht
I included the start velocity in my UDF as suggested by pakk and it worked without interuppting the simulation.
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 06:34
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 21:16
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 19:54
